intake manifold
- sinix3
Re: intake manifold
i have a gs so yeah first kl haha. looking forward to alll the extra power and not burning oil XP
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
- sinix3
Re: intake manifold
so seems how my millenia intake is missing pieces im thinking about just using my k8 intake until i can find a klze or fix the millenia intake. any ideas or should i just fix the millenia intake before starting my swap. i could use some help figuring out the vris electronics if anyone has some idea
Re: intake manifold
Missing pieces?
- sinix3
Re: intake manifold
It is missing the solenoids for the Chris and one of the vacuum valves like the vacuum part that opens the valve. I fabricated one of them up but idk about the solenoids
Re: intake manifold
Should be interchangeable from all intake manifolds, including the K8
- sinix3
Re: intake manifold
ok i just have to figure out the vacume routing then. would you happen to know where i can get a diagram for that?
Re: intake manifold
![Image](http://i30.photobucket.com/albums/c302/solo_ryder/vaccumediagram-1.gif)
Re: intake manifold
The solenoids them selves are interchangeable...
- sinix3
Re: intake manifold
you wouldnt happen to have a k8 vacuum diagram aswell would you?
- sinix3
Re: intake manifold
and do you know if i can use the millenia egr or do i have to use the k8?
- MrMazda92
Re: intake manifold
The EGR will not swap over, unfortunately.
I have a K8 IM and EGR I could part with. ;D
Re: intake manifold
I might still have my KLDE egr valve in a box some where...
- sinix3
Re: intake manifold
No i have a k8 intake and exhaust and egr lol i started te swap today. I just put a little plate over the egr on the intake and will leave the age bolted to the block so i dont get any ce codes. Wish me luck. Tomorrow i start plugging everything in and fire it up
Re: intake manifold
viewtopic.php?f=2&t=80489
-4- VRIS Solenoids, i have 2 of these 15 each
-5- EGR Solenoid w/bracket 5
