weede`s KL-ZE Supercharger - Megasquirt
MrMazda92
Re: weede`s JDM MX-3 KL-ZE Supercharger
Post by MrMazda92 »
Definitely cool :) I haven't messed with my MegaSquirt much yet, as I'm still lacking a few things I hope to get my hands on before tuning the car. It'll happen eventually though! :D
mitmaks
Post by mitmaks »
And washed car preparing for engine rebuild :)
Which rims/tire size are you running, how much did you lower car? Car stance is perfect!
weede_klze
Post by weede_klze »
Thanks! :)
My setup:
Tire: Yohohama AVS Sport 205/50/16 (in next season i`ll buy Yokohama Neova Ad08)
Rims: 16/7
Ground Control Coilovers set: I thing max -50/60 mm
Eibach camber kit in front - 1,5 deg
weede_klze
Last parts :)
Propefect DV
I`ll use DV not Bov like i said before. My system will looks that:
and new wheel:
btw my ori mazda 323 gtr wheel is for sale :)
bbunkerc397
Post by bbunkerc397 »
The wheel looks nice :D Almost like my MOMO Tuner wheel.
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
93DrunkMx3r
Post by 93DrunkMx3r »
man i would love to get my hands on your old wheel n cover car looks great! I cant keep my eyes off your work log.
weede_klze
little more simulations...
I used Eaton`s sim: http://autoapps.eaton.com/Simulator/EngineDetails.aspx
And for KLZE -> 2.5l , CR 10.1 , IC eff. = 50%, VE=80%, pulley 76mm ( drive ratio 1.8 )
We gets:
We will see how about practice for it :D
Post by Josh »
That seems about right. Looking forward to seeing this done, nice work on the diverter valve. Should save a bit on fuel economy too. Did you upgrade the internals of the supercharger? I was reading on the efficiency of the newest styles of the M62 and they are supposed to be amazing over the previous screw design.
weede_klze
Josh wrote:That seems about right. Looking forward to seeing this done, nice work on the diverter valve. Should save a bit on fuel economy too. Did you upgrade the internals of the supercharger? I was reading on the efficiency of the newest styles of the M62 and they are supposed to be amazing over the previous screw design.
What do you mean internals? DO you mean porting inlet? A have 5th version od m62.
Post by Josh »
I was referring to upgrading the screws to a newer style, the 5th gen is good. Did you port it?
weede_klze
Josh wrote:I was referring to upgrading the screws to a newer style, the 5th gen is good. Did you port it?
No I didn`t....I want only change oil for new and thats all - i will see what pressure will be generate.
weede_klze
I decided to run with stand-alone Megasquirt MSII :)
We want to take absolutely all the hassle out of setting up a standalone on your Mazda with the K series V6 engine. Because of this, we came up with this Plug and Play ECU that is much more powerful than your stock ECU and that can be installed or removed in minutes without having to touch your OEM wiring. This ECU completely replaces the stock one and it gives you limitless modification support capabilities whether you're running a forced induction setup or normally aspirated.
Mazda V6 vehicle specific features include:
- Full control of fueling and ignition timing for any type of injectors used
- Full control of both VRIS stages including onset RPM and duration
- Control over both cooling fans (important for turbo vehicles)
- Pre-wired launch/flat shift control that you can set and enable as desired
- Pre-installed boost control solenoid driver
- Full air conditioning functionality kept
- Electronic idle air control
- Fuel pump control
- Your dash gauges and lights work as they do stock
- No splicing, cutting, soldering or touching of your OEM wiring harness
- Base/start-up map for your K8 V6
Based on the MSII processor, our ECU has an injection pulse width resolution of 0.001ms and our PNP unit comes standard with many other built in features so that you can easily add peripherals to the system without having to solder components inside the classic Megasquirt case.
Technical Standard Features of every Stratified MSPNP ECU kit:
- Fully programmable MSII ECU based on Microsquirt technology
- 2 injector drivers
- Up to 4 logic level ignition drivers
- PWM idle air controller
- Fuel pump control
- Professionally assembled and tested ECU ready to be installed in your vehicle
- Installed 2.5 bar MAP sensor (upgradable to 3 bar and 4 bar)
- 3 protected low side relay drivers (fan drivers, solenoid drivers, VICS)
- 1 protected boost control solenoid driver (for adding a boost control solenoid)
- 2 digital switch inputs (launch control, flat foot shifting, map switching)
- 3 expansion slots for Expander Boards (we plan on releasing knock sensors, additional injector drivers, spark drivers, and other useful circuits to add to our units in the future)
- Proto area
- Intelligent input/output removable jumper configuration that allows solder-free addition of external sensors and actuators (Wideband, IAT, CLT, etc)
- DB9 (serial) tuning cable connection
- External 12V connection for flashing the unit outside the vehicle
- Tachometer output
- Knock sensor input
- CAN network connection
- Extruded aluminum case
- 5 feet of vacuum hose
- One on one support until your vehicle starts and idles
- Warranty against manufacturing defects for 3 months from purchase
and my friend prepared for me smaller pulley:
waiting for spring ;)
sinix3
Re: weede`s KL-ZE Supercharger - Megasquirt
Post by sinix3 »
Where did you get the ecu? Im thinking about doing this set up for my car. Not sure if i should go with the aem or mega squirt. So far im not even sure if aem makes a set up for our engine but will be looking tomorrow.
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
crazycanadian
Post by crazycanadian »
sinix3 wrote:Where did you get the ecu? Im thinking about doing this set up for my car. Not sure if i should go with the aem or mega squirt. So far im not even sure if aem makes a set up for our engine but will be looking tomorrow.
Hey bud, he got it from these guys...
http://www.stratifiedauto.com/
They are local to us... based right here out of the lower mainland...
weede_klze
Yes, i have it but still not in car - in Poland is still winter :(
