hei mod whats this wire from?do i need it?with lots of pics
lucifernl
Post by lucifernl »
hi all
i have some questions.
im wirring my hei mod(again)
now i solder the connections for good
but i have no spark i dont know why
can you help me check the wires?
this is how i wired
redrawn the wire diagram
Orange Ignition pulse ----> W
the Hei Earth ---> G--->hei mountin point.
Yellow blue.tach signal ---->1k---> (go to coil - red)
red coil- --->coil ---> C
the disty
coil and hei
but where are these from
connect them?
made the new hei wires
Hei Coil + and Coil - Connection to Hei
Coil+ and Coil- +tacho connection(inside fuse box 1k ohm)
the connection to original harnas( tacho coil + and coil-
Re: hei mod whats this wire from?do i need it?with lots of p
Hard to tell just from your pics. What side of the coil is + and what's - ? I suggest you retrace every wire checking continuity as well. What year is your car?
lucifernl
Post by lucifernl »
my mx is from 1992
i install my wires new harnas tomorrow
but where are these from?
lucifernl
Post by lucifernl »
B+ red --->B on hei B-blue--->C on hei
WhiteFinish
Post by WhiteFinish »
It looks like you only ground the W and hole near C through the hole at C.
I grounded it extra from W
Nederlands.
Volgens mij moet je de draad tussen W en C ook nog een keer extra aarden, niet alleen het gat van C, maar een afsplitsing bij W naar het chassis.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
lucifernl
Post by lucifernl »
i make the extra grounding point.
connected the coil wires and tacho from orginal harnas to mine
yellow--->tacho
red--->coil -
bleu--->coil +
to be melted
coil+ --->B
coil- --->C
when i crank i get still no spark from the coil
coil resistance is good coil lead wire to.
i get a pulse signal to the Hei--->g
but when i set my car in second contact
i get voltage at both coil terminals
coil+
coil -
lucifernl wrote: but where are these from?
If this wasn't such a PITA for you it would be funny. That's your VAF plug and without it plugged in you ain"t startin nothing. So plug it into your vaf and hey,,,,have a nice day. :D
lucifernl
Post by lucifernl »
lol
i know that the vaf plug needs to be connected
i took my intake out to take decent pics
and its not the plug its the wires beside.
lucifernl
Post by lucifernl »
when i crank my car coil+ stays at 12 v.
but coil - goes out with a testlight and wont light back up again.
no pulse from hei?
Check the wire colour code in our on line manuals. http://www.mx-3.com/manuals/index.php
lucifernl
Post by lucifernl »
i was and looking for it in the manual but i cant find it
lucifernl
Post by lucifernl »
when i start the car i get no pulse signal to my coil
i get 12v on coil+ and coil - thats ok,but while i am crancking coil - should give ground pulses.
but i dont get them.
i have pulse to the hei
have earth
have power on the coil
is my hei broken already?
greetings kevin
lucifernl
Post by lucifernl »
i made a new earth wire i spitted id and now i got a spark from my coil. yeah!!!
but i have no spark on my spark plugs
sanded the contact points and rotor
is the disty broken?
lucifernl
Post by lucifernl »
i routed the wire back and it whas a earth wire they ar all going to 1 kable in the harnas.
but still no start
have spark from my coil but not on my plugs
