hi all.
i am kevin from holland and ik have a problem with my klze longneck.
the problem i have my car wont start even i drove it to my parking spot.
my car cranks but wont fire.weak spark in beginning
i start checking
i use the ze disty
sand contact points
bought a new coil stil no good luck
then i bought a hei module still no luck
but now i have no spark at all
i checked my wiring 3 times
they are ok
checked ecu trigger pulse signal with led
my lead wire from the coil to the disty has 8 ohm resistance thats ok.
but 1 thins seems wrong the coil+ and the coil- mesure 12v at the same time is that ok?
i have no spark now at all
plz help me
greetings
mx3fan from holland
KLZE With Hei mod and Ext Coil no spark
Re: KLZE With Hei mod and Ext Coil no spark
just checked of the power switches on the terminals from the coil they stay both at 12 volt.
no pulse to coil?
plz help me
no pulse to coil?
plz help me
- BornSticky
check your wiring with this write up http://www.clubprotege.com/wil/howto/hei/index.htm
its the one i used and it worked well and make sure to put the plug wires to the numbers that corespond to the cap so 1 to 1, 2 to 2 etc.
#5389 to join MX-3.com
The caps/spark plugs are conected the right way thats not the problem i followed the same guide bit no luck
Re: KLZE have spark and fuel but wont fire up.
i rewired as the post above it didnt have to change wires but i have changed al connecions.
i have a spark at my coil
if i atach the sparkplugcable to the coil i have a spark at 1 bougie.
my distribiturcap has 5k ohm resistance
check spark plug against engine have a spark
when i whas checking my disty the bolts where loose.
i put the disty back on my timing mark
she is sounding thats she wanna fire up:(
i have fuel pressure but my baby wont fire up.
- WhiteFinish
ok, so spark when directly connect it to the coil.
When the coil is connected to the distributor you also have a spark on each sparkplug ?
Try everytime with cil 1 upto 6 and see if it sparks.
- WhiteFinish
Appeared to be the Coil.
He's still having some trouble with starting.
First needs to crank, when stopping cranking the car will fire up.
