AaronTietje - 1993 MX3 Phase 2
Re: Headliner.. AaronTietje - 1993 MX3 GS
Post by Josh »
pillars look great! nicely done.
AaronTietje
Re: Countdown to H2o.. AaronTietje - 1993 MX3 GS
Post by AaronTietje »
My big plans are to get the car up and running for the H2o car show in Ocean city this September. I need to have the car on the road in the next two weeks so that I have time to get any "bugs" worked out before the show.
Anywho newly completed work:
The rolecage in now bolted and seam sealed in.
The rear interior is in.
The Driver Seat is finally mocked up...... I have no more than 1/8in of space between the sparco seat and the door panel.
Mazdaspeed pedals are in....... I ended up modifying the complete protege gas pedal assembly and using it inseat of just the aluminum pedal portion.
And I got some more parts.
Planted side mount brackets,
No name harnesses to just get me by,
two new hankook tires,
Honda firewall plug for my deleted ac,
Boss hub kit,
Sparco wheel
kulluminati777
Post by kulluminati777 »
oh wow i thought the only after market seat brackets were only made by mazdaspeed its cool to know there is others and those pedals are pretty cool bro :freak:
JayoM
Post by JayoM »
Roll cage is awesome!
AaronTietje
UGGGGGGGGggggggg.......
Spent the day putting the mx together....well more together.
I didn't get a ton done but I did get the axles in the JDM LSD trans. The JDM LSD comes out of the Lantis type R and you MUST have the input shafts for the axles. The driver side input shaft is about 1/4 in longer so that the snap ring will seat . It also has oil groves (they look like riffling) on the shaft. The passanger side 3 bolt intermediate shaft from the Lantis is also necessary otherwise it will not even bolt up.
I also had to rebuild a driver side axle using the lantis input portion of the axle along with a mazda mx3 driver side axle.
AaronTietje wrote:I didn't get a ton done but I did get the axles in the JDM LSD trans. The JDM LSD comes out of the Lantis type R and you MUST have the input shafts for the axles. The driver side input shaft is about 1/4 in longer so that the snap ring will seat . It also has oil groves (they look like riffling) on the shaft. The passanger side 3 bolt intermediate shaft from the Lantis is also necessary otherwise it will not even bolt up.
Pretty much the issue that we've been dealing over in North America for years. It's not getting the LSD trans that's the issue, it's the other parts that are.
AaronTietje
Getting closer.........and I got a tow hook:
youdirtyfox
Post by youdirtyfox »
Ohh really close now! Decent stance your pulling off there too Bro :D
Sleeper6
Post by Sleeper6 »
See what I want to know is will you be brave enough to keep up with me a will on some gravel back roads now with that pretty car? :twisted:
AaronTietje
Sleeper6 wrote:See what I want to know is will you be brave enough to keep up with me a will on some gravel back roads now with that pretty car? :twisted:
Heck no...... 5mph on bumps and no hitting woodchucks....BUT clean clear roads here I come.....o.....wait......I live in NY STATE :crying:
SgtLynch
Post by SgtLynch »
POOOON3D!
Sleeper6
Post by Sleeper6 »
I might drive by on sunday just to make you jelly now for that lol
AaronTietje
I'll be here. I've got a huge garbage bag of mx parts that you need to go through before to toss them.....And I still have your door panels sitting up in the rafters.
AaronTietje
Out of it's dungeon for the first time in two years.
It's a video so just click on it.
Last edited by AaronTietje on September 13th, 2012, 12:18 pm, edited 2 times in total.
Sleeper6
Post by Sleeper6 »
winning! that idles not too bad either for the colts
