Level of difficulty...
kulluminati777
Post by kulluminati777 »
how hard would it be to get these mirrors to fit on the mx-3, like how much cutting fiberglassing would you think is involved because i know its possible...just need a little modification and no there nothing like the ebay ones, they dont stick out as much but if it proves too hard i might just get ebay ones, there made by ganador for the mazdaspeed demio (mazda 2) from the 90's i believe
Re: Level of difficulty...
hmm the tops look pointy enough.
Fowljesse installed some "M3" style mirrors. I can't tell if the ones in your pics are the same...
Check out his pics and notes about installing them: http://www.mx-3.com/phpBB3//viewtopic.p ... 8&p=493918
RobMinhas
Post by RobMinhas »
Why not just get these? http://www.ebay.com/itm/92-96-MAZDA-MX3 ... 19d087cf2d
I belive YouDirtyFox installed them and they were a direct fit.
youdirtyfox
Post by youdirtyfox »
Insanely diffilcult! I looked at fitting some vitaloni california mirrors to mine, the problem being were the wing meets the door you have to a large piece that flows them both together then flows into the mirror, get that wrong and it will look terrible.
The only way to get it to work would be use the base plates from the ebay mirrors then mould/affix the ganadors into that, you are talking big bucks then as I thought the ganadors alone were like 200 quid a pair.
mx3matt
Post by mx3matt »
sounds like LOTR lol.
i didnt even realize that was an actual style of mirror, i just thought it was m3ish style.
RobMinhas
Post by RobMinhas »
youdirtyfox wrote:Insanely diffilcult!
I eat my words.
kulluminati777
i may just get the Ebay m3 ones because the ganadors cost alot to modify all willy nilly, i just wish the m3's didnt stick out as much
youdirtyfox
kinda with you on that, begs the question could you cut a section out the M3 mirrors so they sit in more!! I looked at mine and i think it could be done...
Return to “Appearance”
