Tavman's - 93 White BPT
- Evo_Spec
Re: Tavman's - 93 White MX3 BPT
yay!
so i'm not sure if you've gone over this but what left needs to be done now? tranny and intercooler piping? or was it a lot more than that?
- Tavman_1213
What needs to be done for it to run:
- waterpump, timing belt and pulleys(plus new springs)
- needs a clutch (still not sure which one ACT or Compation Clutchs for my G-seires)
- axles
- front brakes
- outer tie rods
- intercooler piping fitted to FMI
- BOV
- boost gauge
- shift knob
- exhaust(going with 2 1/2 straight to more that likely a magnaflow 2 1/2 in to 3 out, NO FART CANNONS ALLOWED!!!!)
- plus all the fluids!!
That is the list of bare minimum of things to make it run. Now what I am going to do(money permintting) is alittle different:
- head gasketset with ARP head studs (can't find a head gasket set for less that 200 in town not sure about the rockauto ones and how reliable they are)
- intake, exhaust and ported head need to be sent away to be flow tested and portmatched(the head is a surprise)
- Mazda Speed LSD (a buddy gave me a GTX AWD tranny that I am going to rip apart to see if I can steal the LSD but I'm pretty sure the only thing I can take it the 5th gear which is the same as the 626 ratio)
- KYB springs, eibach lowering springs and new strut mounts plus boot and stops
- Rear disk brake convertion (which will mean new rear brakes)
- 90 amp alternator
So it is still a pretty big list but its just buying alot of the big ticket items that is slowing me down right now (money is slowing all of us down haha)
A buddy sold me a set of 16" Motegi's with 50% rubber for $200 bucks no pictures yet.
- axles
- front brakes
- outer tie rods
- BOV
- boost gauge
- shift knob
- 90 amp alternator
93 White RS- BPT Built not bought!!
Worklog: viewtopic.php?f=46&t=78988
- Evo_Spec
oh ok, so it's all engine/tranny stuff basically, the actual car's all good?
Actually, any idea what colin put on the 323 he sold me? i just assume it's a fart cannon, never really looked.
mine went straight in without modification and best of all, free...ish, can't complain. =DTavman_1213 wrote:- exhaust (NO FART CANNONS ALLOWED!!!!)
- Tavman_1213
Yeah I wants to replace ball joints and stuff besides that only a couples spots were some rust is(not to concerning only surface)!! oh an I need tail lights(toying around with all red stock ones or blacking out stock ones, going to borrow robs to see about the black ones)
You are more than welcome to come an see it(it's isn't movin hahaha) whenever just give me a shout!! That's also an invitation to anyone else in the area that wants to take a look at a non moving car haha!!
Who needs a shift knob to run their car! Just don't drive it in the coldTavman_1213 wrote:What needs to be done for it to run:
- shift knob
- Tavman_1213
Haha I am not used to grabbing small rods I need something that is similar in size!!! Hahahaha
- Tavman_1213
I got a set of stock tail lights and have installed them because I'm not the biggest fan of the altezzas! My car came with chrome ones and the looked like crap and I don't think the black ones would look all that good! Plus I ripped my head light plastic cover off to clean an polish the inside of my head light plus maybe do some painting....... but I was wonder with the people that have done this did you put the metal piece that surrounds the bulb back in or just remove it all together??
Also picked up a set of 5 spoke stock rims for cheap. 2 of them are good, which will match my 2 good ones tha came with my car. The other 2 aren't bad but there was some curb rash on them!!
- Tavman_1213
Just wanted to post the pictures of what I've been doing!
- Tavman_1213
Hey had a question about what gasket set I should buy and was wondering if any of the BPT guys or anyone else for that mater have used this gasket set from Rockauto: VICTOR REINZ Part # HS5878 or have had any problems with this brand of gaskets.
I would love to buy a Felpro one but they are way to expensive. Let me know thanks
Re: Tavman's - 93 White MX3 BPT (Gasket Questions!!)
Topline from http://www.importperformanceparts.net/ just as good as oem
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- Tavman_1213
Thanks Mike I was hoping you would answer haha!
- Tavman_1213
Re: Tavman's - 93 White MX3 BPT (Speedo issue!!)
So was bored today and still waitin for my gasket set to arrive so decided to paint the needles on my speedo! All went well but after I had it together I noticed on the back that on of the wires in the strip was broken and have not been able to figure out what it does an I don't know what it stands for! It goes from the connector to a stainless screw in the back labeled RSW!
Also removed the two white pieces of plastic to let more light get through.
Here the pictures of the wire
I want to figure this out before I put it back in!!
It looks like it's a ground because of the crew that it connects to, they wouldn't do that for a positive feed.
Picture is too blury, but looks like just the copper is showing? Or it is actually broken?
So the question is if it shorted out from a short, or if it burnt out because of excess load?
- Tavman_1213
It is actually broken! But with out my car even close to be able to run I can't tell you what is effected by it! The only thing I could find was on a miata forum an they say it controls the speedo
- Evo_Spec
is it electric or mechanical? cause i have a spare electrical one i can give you, or even just that back "wiring" piece
*edit* also if it's electrical i can probably tell you what it is if i look at mine but i'm going out now so i'll reply back tonight if you don't get any info
