quick question on the V6 Alternator swap.
Dark_Rider2k3
Post by Dark_Rider2k3 »
I sold a member my V6 alternator, but have a quick question that I can't seem to find via search:
Do you have to swap the bolts when swapping the V6.
If I can remember correctly, the bolts won't just go on like they did with the 4cyl alternator. I think you have to "swap" the bolts.. but I can't remember how you "swap" them.. is it which one goes on top and on bottom, or is it the actual physical direction (like instead of it sliding in from the back of the alternator, you slide it in from the front to lock it on?
I just can't remember how the V6 alternator mounts up on the 4cyl motor.
SuperK
Re: quick question on the V6 Alternator swap.
Post by SuperK »
YOu have to swap the pulley as well. I ended up going to Ace Hardware to find a bolt and nut that fits, otherwise you have to use the long bolt from the GS.
I think you have to slide it in backwards too, it's been a bit of time...
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
My GS Worklog Thread
Dark_Rider2k3
SuperK wrote:YOu have to swap the pulley as well. I ended up going to Ace Hardware to find a bolt and nut that fits, otherwise you have to use the long bolt from the GS.
Okay yeah he's havign an issue with the long bolt.. I'll have to source him up one..
And pulley was swapped.
SuperK
Post by SuperK »
you should send him to ace hardware!
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
Post by Josh »
Why did you have to swap the pully? is he using it on a SOHC?
And all you should have to do is put the bolt in from the other direction. It can be a PITA but you can wiggle it in there.
SuperK
Post by SuperK »
on my dohc, the pully had a different amount of bands than the V6...
Bane
'93 Mazda MX-3 ZE
She Hates Me
My For Sale Thread
My Feedback Thread
im2bad4ya
Post by im2bad4ya »
This whole thread is in reference to the GS alt I got off of Dark_Rider. Check out my work log for the workaround, rant and eventual installation of the alternator
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Post by Josh »
SuperK wrote:on my dohc, the pully had a different amount of bands than the V6...
You don't have to change the pulley its wider than the RS belt so you still get full grip. :wink:
