![Image](https://lh3.googleusercontent.com/-ky2Z_rIcNmU/TyBva9eb3ZI/AAAAAAAAA5Q/jpjQ2099NCk/s800/2012-01-25%25252021.56.43.jpg)
![Image](https://lh6.googleusercontent.com/-ppyVO2F9ui0/TyBve11ScNI/AAAAAAAAA5Y/41gfRcLblz8/s800/2012-01-25%25252021.56.03.jpg)
Should I move the plate with the tips to match the original? That difference on the crankshaft sensor seems important.
Any information will be apreciated.
Thanks!
I can fix that easily, just new holes and screws turning the plate to match the original pulley.Ryan wrote:Ha.
I'd send it back, honestly. You can't just fix that.
The cheap-o ones have been known to come apart too, often with catastrophic results.
http://forums.probetalk.com/showthread. ... DP+failureI have good and bad experiences with UDPs...
The bad one was a cheapo Ebay one.
Constant slight misfire...retarded ignition timing.
Replaced every bit/sensor of the engine.
Fried two coils...loosened my mind.
Turned out to be that the trigger wheel was wrong aligned
i had an ebay one and th 4 screws on the back plate decided to fall out and the plate knocked out my crank sensor and stalled the car and 3 bolts decided to get imbeded into my timing belt lol
