[WTB] Engine harness and charge harness for obd1 v6
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
gerald_23
Post by gerald_23 »
I'm currently looking for the engine and charge harness for my 94 gs. I have a klze and as I understand the stock engine harness will work for what i need. I'm not too sure if the charge harness (from the alternator to the starter to the battery and fuse panel) is different at all. if so then i need one for the klze. I'm in Hamilton Ontario if anyone is looking to ship
gerald_23
Re: [WTB] Engine harness and charge harness for obd1 v6
Post by gerald_23 »
Still looking!
Why don't you explain what your problem is. 94 is unique in so far as the ECU and disty go. Do you need to use a disty with a cam sensor for mega squirt?
gerald_23
Post by gerald_23 »
Ok. Long story short this car is far from wired properly. I bought the car in October and before I could do anything to the car the starter area caught on fire while cranking. It would cranking but not start. After 3 attempts at cranking it one day I saw smoke and then...fire. It burnt the engine harness pretty badly and the wires to the starter and the pos wire to the battery. So right now i'm on a mission to fix it so i can atleast get my car running. This was suppose to be my winter project but this is a huge bump in the road. As far as ecu and disty go the car has a stock computer with a probenator chip and the does not have megasquirt. I'm sorry if you need more info but I'm still trying to learn alot of the technical stuff with this car
gerald_23
Post by gerald_23 »
This is Ramsen_25 old car if that helps. He said you did help him quite a bit
mazdaspeed23
Post by mazdaspeed23 »
gerald_23 wrote:I'm currently looking for the engine and charge harness for my 94 gs. I have a klze and as I understand the stock engine harness will work for what i need. I'm not too sure if the charge harness (from the alternator to the starter to the battery and fuse panel) is different at all. if so then i need one for the klze. I'm in Hamilton Ontario if anyone is looking to ship
hey i have a complete 94 harness from back to front. it includes, fuse box. all the wiring you need to install
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
Really the ECU is fine unless he was ODBII (which he's not since he's running a Probinator), he would just need the harness, and with the matching disty to make his life easier in trying to track down the proper one.
mazdaspeed23
thats excatly what i had in mine, was a probinator chipped ecu, with an exteranl coil setup. still have the harness and coil setup.
Own
2007 Ford Fusion SE
Return to “MX-3 Related Want to Buy Forum”
