Look what happens when your mechanic sucks
im2bad4ya
Post by im2bad4ya »
Ball joint came loose from the spindle, (my mechanic put a new axle in about 2 weeks ago). Luckily (where I got the name for the car, so many close calls, always come out unscathed) i didn't hit anyone and my car escaped unharmed. Happend as I was coming down a circular ramp turning left (going from the overpass leading to the underpass). Happened as i got to the bottom of the ramp, about 25/30 MPH. Just so happens my car rested 100 yards from an auto mechanic shop, so they checked it out and gave me the diagnosis. Everything is cool except I now need a newER axle because the boot ripped, but for practical purposes, the car is still drivable. (BTW, the scrape on the turn signal was from a previous fender bender, unrelated to this incident)
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
mitmaks
Re: Look what happens when your mechanic sucks
Post by mitmaks »
How did ball joint come out of spindle?
Ryan
Post by Ryan »
Someone forgot the pinch bolt.
Or didn't tighten it.
I see this a surprising amount on the side of the highway. Losing ball joints or tie rod ends, tire doing an abnormal 90º.
Glad you and the car are okay.
Now you get to soak them for whatever broke :D Check your strut top, see if it is damaged. The rubber isolator may be totally shot now. Your strut may be bent as well.
(Side story, had a friend who went to a shop and they forgot the bottom hose clamp on the rad.... they bought him a new motor)
im2bad4ya
Post by im2bad4ya »
yeah, pinch bolt wasn't all the way tight. They guy who looked at it said "Just curious, why is all your suspension brand new? was there issues with the old setup?" I explained that it wasn't a problem, more of an upgrade, replacing old tired stuff with new stuff. He says, "Well, I don't know who your mechanic is, and I'm not saying anything personal, but he probably just put the stuff together, perhaps forgot to tighten it, didn't do as a good a job." I think I would have damaged more if was going faster and skided along the highway, but from the point it came apart to the point I stopped, was probably a couple of feet, not enough to drag things along or snap the brake line or anything crazy.
There is a licensing standards for mechanics, try to find out who that is in your area and report this to them. He may gt a fine or at least get a warning. Start at your local DOT. Keep us updated on this.
