Hi I'm new to the forums as I am new to owning a mazda. I just bought a 1996 Mazda MX-3 for my sisters grad present. Just went and bought her $1200 worth of kenwood car audio (with another 5-$800 on the way) and need help getting power inside the car from the battery (Semi-professionally fits this case best). I only have another day or two to get this done and any immediate help would be GREATLY appreciated. If you feel comfortable shooting me a text you can text my cell at 1-867-334-5627 or respond here. I will be back and fourth from the car to the computer figuring things out.
Thank you for your time and I look forward to hearing from somebody shortly!! :]
Car Audio: Power wire from battery to inside vehicle. HELP!
- muttpower
Re: Car Audio: Power wire from battery to inside vehicle. HE
If you're going directly from the battery, on the driverside firewall, under the hood, there is a black rubber grommett, approximately 2 inches round...just pry that out with a flat tip screwdriver, drill a hole in it, or cut an X in it, run your wire through it, and re-insert the grommet back into the hole on the firewall. the hold exits on the interior driver side, under the dash, above the pedal assemblies...pretty straight forward,..
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
- CarolinaCartel
yep i put 2 runs of 0/1 ga wire throught that hole.
1993 Mx-3 Gs
09 Setup
Headunit: Pioneer DEH-P80MP w/CD-IB100II & 60 gb Ipod
Speaker: 2 pr MB Quart ESA216 6.5" COMPONENT
Subs: 2 Sundown 15" Nightshades
Highs amp: Sundown SAX-125.2
Sub amp: Sundown SAZ-3000D
Electrical: All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
09 Setup
