swap wirring issue :(
- newdriver92
So I have a 92 mx-3 gs atx and I'm puting in a 95 pgt mtx in and all is smooth,.... Well until it came too the wirring and I read the guide in the faqs and they did mention the yellow plug but the author failed to mention that there is 6 pins in 2 rows so with it not being the way he described it and now I'm confused :s so I would like a llittle help and another issuee is the neutral switch
worklog viewtopic.php?f=46&t=77147
other pics of the adventures me and the car have been on http://s1082.photobucket.com/home/newdriver92/index
Re: swap wirring issue :(
i need to find this out too for my swap as well.
- Ryan
The best way to do this is to use an MTX harness as well. There is some anomaly that I haven't found a solution to that stops the VRIS from working when you use an MTX ECM with an ATX harness.
I don't know what yellow plug you're talking about either.
The STARTER INTERLOCK gets wired into the ATX's park/neutral switch.
The neutral switch gets wired in seperately, for use in the A/C and idle controls, as well as the clutch switch.
Don't confuse them, they seem the same, but have different jobs.
- newdriver92
where do u wire in the neutral switch
- Ryan
- newdriver92
Thanks ryan
