Been up since 5:30 this morning all ready to fit up the radiator...
unfortunately I cant finish the install as the thermostat housing is 30mm not 35mm as I first measured
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
means I need to order another reducer for that end before I can complete the install.
Some progres and fitment pictures though, as you can see the bottom hose and mounting point is spot on.
The all important gap (around 3") for the boost pipes to pass through.
slam panel needs new holes cut
heres a good tip for cutting silicone hose, run the knife around a hose clip
to get a nice clean straight edge.
so this is about as far as I can go today, got to decide wether to put it all back to stock ready for monday or car share with the missus until the reducer turns up...
![Image](http://i23.photobucket.com/albums/b393/djsonofsam/Photo0598.jpg)
