MS3 PnP for klde
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
mx3_aruba
MS3 PnP for klde
Post by mx3_aruba »
hi all,
this year i'm beginning a project on my mx3, by doing a klde swap and a whole lot more. my plan is to go stand alone with the MS3 DIYPnP.
my question is:
if i only want to keep the engine very simple, with custom intake manifold, custom headers with O2 sensors, with no vacuum lines, no VRIS, what so ever, will this PnP system still be working? would i still need the bulky MAF sensor?
if NOT, which MS system should i use?
Someone with actual experience please help me out, cause i'm leaning towards MS for the price, because here in Aruba, everybody loves and uses MicroTech, but it's expensive as hell.
Re: MS3 PnP for klde
It doesn't matter how stock or modified your engine is, Megasquirt will work
You NEED to use an GM IAT sensor to replace the factory VAF, so it does get rid of that thing.
mx3_aruba
Post by mx3_aruba »
tnx buddy..
yeah i meant VAF, my bad..
do you have any experience yourself with doing such a mod?
Worked on a few, not alot of experience with them
Return to “Engine Electronics/Tuning”
