My MX-3 is in such old, crusty shape that this is the last thing I should even be thinking about. But just out of curiosity, any of you guys replace or make your own back hatch cover? Gotta be likely since the stock thing that came with the car is so flimsy. I remember mine was all dented & caving in from the get go. Seems like it was a crappy little hinged thing, with 2 straps that were supposed to raise it up when the hatch was opened. It's a weak little carpet-y plastic thing, and inevitably, someone's gonna set something too heavy on it, and it gets all bent and dented in.
I did what I'm guessing a lot of MX-3 owners might have done--measured the area, cut out a piece of thin plywood that size, and glued thin black carpet on top. I also cut out 2 holes for 6x9 speakers, which was sort of a lazy way to "upgrade" & bypass the little stock speakers that are mounted back there in the plastic sides of the trunk.
I was just thinking about this since I noticed mine's gotten pretty beat up again--the sheet of wood (luan?) I used was probably too thin, and is starting to break. Thought it would be cool to hear about, or see pics, of what others around here did to "upgrade" the back trunk cover thingie.
Back hatch/trunk cover - DIY...?
Re: Back hatch/trunk cover - DIY...?
People have all the time. I did one to point my CarPC on, J-Beef and others have for subwoofers.
THere's also this:
http://evilyeti.com/
THere's also this:
- fillpereira
Just found this online, not my style but i thought it was unique....
Is that site even still active? I did a repair job on my hatch cover the but where the pivot brackets mount is just too weak to hold it up. I'd order one but their last update was 2007...Nd4SpdSe wrote:People have all the time. I did one to point my CarPC on, J-Beef and others have for subwoofers.
THere's also this:
94 MX-3 RS Blaze Red
