ENGINE PROBLEMS WITH MY MX3 KLZE
snoopyKLZE
i got some problems with my mx3 KLZE swap been trying to figure out whats wrong with it but i cant figure it out i will pay if some one on the form can come take a look at this thing i live in Brampton plz and thankz number is 647 686 6532
Re: ENGINE PROBLEMS WITH MY MX3 KLZE
Ok buddy, you need to sort things out:
1) No need at all for caps, it's not life or death, we'll see the threads
2) This section here doesn't apply to your problem, and actually, you don't evern know what the problem is yet. This is related to tuning and installing aftermarket engine management systems. The "V6 Technical/Performance" section is the section you want, your KLZE is a V6 and you're having a Technicial problem
3) Put all your information in one thread, you don't need 5 different topics, and they're all related to your motor swap. It also helps us to see all information since we don't have to jump between all the threads to see all your problems, they all might be related. If you want help from us, please try to make it easier. If you're using that to bring up your post count over 30 to sell stuff, we're not stupid, we notice and we'll
4) A KLZE and KLZE swap shouldn't be anything special for a good mechanic, especially since it's using the same motor and sensors from your K8. If you've got a good and reputable mechanic, he can help you out.
