Hi there
Searching the forum i've found info about the intake hose cracked, mine is also cracked, so i guess is causing my rough idle...
I want to replace with a kit (i've seen the ford probe kit, prelude...) wich is better?
And the most important thing for me: what do I do with the 2 hoses that leads the intake hose.
Thanks in advance.
The best solution to replace stock intake rubber hose craked
Re: The best solution to replace stock intake rubber hose cr
corksport makes a stainless header, is it what you need ?
Not the heather, just the rubber tube from the air mass meter to the throttle body.
- Ryan
I have a spare intake hose.... or you can buy a cold air intake of some sort, I think thats what you're wanting.
All the one's I've made were custom...
- DeepBlueMX3
A friend of mine, here in Brazil, did this intake with silicon hoses and stainless tubes;
Ok, thanks
But do i have to connect the 2 hoses (from valve cover and from TB) in it?
- DeepBlueMX3
-Yeap, you must have.ut0pia wrote:Ok, thanks
- Evo_Spec
well the one from the valve cover you can put on a small filter if you wantut0pia wrote:Ok, thanks
like this:
(yes this is mi|<e's car if anyone askes)
