Title says all. I don't have any clutch pressure plate bolts, and cannot find the bolt in 10.9. So can I use grade 8.8?
This is for the BP's transmission btw.
Grade 8.8 bolts instead of 10.9 for clutch pressure plate?
Re: Grade 8.8 bolts instead of 10.9 for clutch pressure plat
Just out of curiousity did you try rochrich mazda? if not theres one out in moon that always seemed to have what i needed. ![Wink :wink:](./images/smilies/icon_wink.gif)
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
yes, but they would take a few days to arrive and I wanted it finished today =(Sleeper6 wrote:Just out of curiousity did you try rochrich mazda? if not theres one out in moon that always seemed to have what i needed.
I believe that Gr.8.8 would be more than sufficient.
The difference between gr. 8.8 and 10.9 is pretty significant, but agree that 8.8 is probably sufficient.
I guess you'll find out. If it were me I'd be willing to take the chance.
![Image](http://imageshack.us/a/img407/384/50r4.jpg)
well I took the chance!
Transmission is mounted, starter is on, half-shaft is on, and trans. mounts are on.
About to drop it in after dinner!!!!!!
- onlytrueromeo
I also agree it should be enough.
I plan to replace most of the bolts on my project car w/ 8.8's, except for the suspension areas.
