Current problem
If I stop the car for a red light, The RPM would drop below 1 ( X 1000) and when I try to relese the clutch the car will jump As if I didn't balance the clutch and gas. I really have o rev up to 3 X 1000 before releasing the clutch to get a smooth start. this happens even if I slow down for trafic . On the 2nd gear I ll have to hold the cluth in a middle position to run it smoothly. or else every time I accelarate or take my foot off from the gas padle the car will jump.
Ongoing problem
This only happens at times. The engine oil indicator start to blink as I am driving how ever everytime there is enough oil in the engine. if I Rav up the indicator will turn off but it will come up when RPM return so normal. If I stop the car for few hours and run the problem will be solved for the next few drives.
Im not sure of these problems have anyting to do with each other. Please let me know guyz where do you think I should start looking for the problem .. ??
