1) The ori. Fuel Pressure Regulator has two Vacuum lines connected to it, on the diagram below no 1 and 2:
![Image](http://img401.imageshack.us/img401/5673/diaw.jpg)
The adj. Fuel Pres. Reg. has got only one Vacuum Line connector -> So I assume that One should be either blinded, or just let it be disconnected or what? And which one should I pick 1 or 2, and what would be the best thing to do with the other?
2) I have huge problems finding "Fuel Pressure Regulator Adapter" to install on the rail and remove the old Regulator -> Will it work fine if I connect fuel Lines to new Presure Regulator and than from New Pres. Reg. to the old one or will the old one decrease the fuel pressure?
Thanks in advance for help
