ok .. so i tried to start it again.. and it just turns over really quickly.
TEST 1 - Check fuses! - every fuse in car is ok
TEST 2 - Check relay's? ( ok here is where it gets confusing.) Checked the fuel injection relay.. thought it was bad.. i basically jumped the terminals different combinations to try starting it as someone turned the key. and oula i got it! i can run the car when briding the terminals that the relay connects too.
so i replaced the relay like 20 times with 20 relays and still no go , i opened the relays and everything is working inside the relay but for some reason i HAVE TO have that wire forcing a connection across these terminals illustrated below in orange
cant figure out why it works with a wire but not a working relay .. what ever controls the relay isnt doing its job what controls the fuel injection relay
