Ok so as with my first post I gave some details about the car and issues its having. Supposedly the ATX was rebuilt 4000 miles ago but that was over a span of the last 5 years. This thing is now slipping like a biotch. When getting on the on ramps and hitting my passing gear it shoots up to 7K then I have to let off in fear of blowing up. It recatches about 4K and speeds up a little then flies back up to 7K. Needless to say the ATX is pissing me off.
I was at the JYard today and found a 1992 MX-3 GS ( Purple ) in fantastic shape and almost completely un-raped.
The car has some 120,xxx miles and the underside look almost spotless. I checked for all the main components for the MTX hardware for the sway and everything seems to be there minus the M-cylinder. They also happen to have a 1993 MX-6 LS with the KLDE and 5mtx. ( this trans would work right ? would I need the shafts ? )
So my main questions are : Which trans is better - MX-3 5 speed or MX-6 5 speed ?
Which flywheel is better / lighter ? MX-3 - MX-6 ?
Is this my complete shopping list :
MTX , Linkage , Shifter Assembly , 3-pedal assembly , Slave cylinder , Flywheel, "Plan to order new clutch kit." Hydrolic lines, Starter ? , CV Shafts ?
What is a realistic timeline for the swap ? This is my D.D. as my 97 Tahoe kills me on gas. Also what could I expect to run into that I should plan ahead for ?
My ATX to MT. =/
- EggyRollz
My ATX to MT. =/
94 Tahoe Sport SS - 454 =)
93 3KGT VR4 - K&N Filter.Proxes 4 Tires. Drilled/Slotted Rotors.
97 Tahoe - Grill gaurd.Oversized Tires.Custom liners.Bored & matched pistons.E-cam.Leather.Remote start.TCC upgrade.+Sunshell.10K tow package.Knifed TB.Flowtech Huggers.Straight pipes.Hypertech chip.B&M Trans Controller, Front diff & T-case plates.
Feedback-viewtopic.php?f=37&t=74259
For Sale-viewtopic.php?f=2&t=74832
Re: My ATX to MT. =/
Go with the mx-3 flywheel or simply go with a fidanza. You can use an Mx6/PGT V6 clutch kit and the mx3 flywheel like I did (if not fidanza) for a little better performance. make sureyou also get the top transmission mount for an mtx and make sure you get the cmc push-rod too
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
- Ryan
you need the clutch master too.
only driver's side CV shaft. passenger is the same.
- EggyRollz
It wasn't there =( so i'm going to have to buy one. I will hit it up wednesday after I get off work. I tinkered with undoing a bunch of in-the-way-crap removal today when I shot down there for some other stuff. Hopefully nobody monopolizes off my hard workRyan wrote:you need the clutch master too.
Also what other vehicles can I snag the master off of ? I would like to be as budget minded as possible with this. Just had a baby in Nov. and nothing really prepared me for how expensive they are
- Ryan
I believe any K or B series engine'd car.
323 being most common. Master unbolts from inside.
- fowljesse
Unless the MX-6 has really high mileage, I recommend getting the tranny from it, since it has a taller 5th gear. You'd save gas, and engine noise on the freeway.
Where are you located? Are you sure the MX-3 isn't a 93 SE? If it has leather seats/ shift knob/ steering wheel, you should get them
- EggyRollz
fowljesse wrote:Unless the MX-6 has really high mileage, I recommend getting the tranny from it, since it has a taller 5th gear. You'd save gas, and engine noise on the freeway.
UTAH unfortunately.
Yeah it has the leather works. Trashed though from what I could see.
I recall the mileage being roughly 205 K.
- EggyRollz
Ok so they crushed both cars sometime between then and now =(
I did manage to find a probe GT with the v-6 and manual trans.
Will the linkage & shifter from the probe GT work ?
Only paid $75.00 for the trans =D
Also if anyone needs KL01 cams let me know since they ( whoever ) stripped the top half of the engine and left the heads in the car with cams uncovered. The look real good too.
- EggyRollz
Ok so I tore into it a bit today. I fould that one of the fluid lines had a clog in it and I suspect that to play part in the sliping issue between 4 & 7k. I put everything back together after flushing the trans and lines out and like magic - no slipping lol.
Anyways i'm still moving forward with the ATX to MTX plan since I already purchased all the stuff for it.
