anyone have any stock front coil springs?
My brothers car has broken coils up front.. anyone lower their car and still have the stockers sitting around? the struts are blown too... but i dunt think anyone keeps those... but jsut in case!? im on the lookout for that too, thanks!
Liquid Neon can be commercialy purchased for $2/liter
1995 Jetta 2L
1988 Pulsar NX 1.8Turbo
(brothers car)
1993 MX3 1.6L sohc
1995 Jetta 2L
(brothers car)
1993 MX3 1.6L sohc
Re: anyone have any stock front coil springs?
I was recently informed by another user that there is a lifetime warranty on the springs and automatic seatbelts. I'll send you the links for the info if you still need the springs.
lifetime warrenty? on stockies??? yes i would like this info... please please please
1995 Jetta 2L
(brothers car)
1993 MX3 1.6L sohc
1995 Jetta 2L
(brothers car)
1993 MX3 1.6L sohc
- Hoodzy
Why would there be a lifetime warranty on a part that usually needs to be replaced.
No such thing on springs.
1995 Creek Mica Blue GS
- umcamara
It's actually a recall on the front springs. And yes it exists. Quite a few members have taken advantage of it.Hoodzy wrote:Why would there be a lifetime warranty on a part that usually needs to be replaced.
So if i bring my shattered coil springs to a mazda dealer they will recall them for me? some sort of extended special policy?
1995 Jetta 2L
(brothers car)
1993 MX3 1.6L sohc
1995 Jetta 2L
(brothers car)
1993 MX3 1.6L sohc
- onlytrueromeo
I believe the front springs only have a 1 time recall, so if its been done before on the car, it cannot be done again, where as the seat belts are a lifetime recall since it's a design flaw.
I'd call mazda to check, otherwise I've got a set of stock springs laying around I can sell to ya.
- Ryan
Yes it exists. the recall number is kicking around on here.
You can tell if its been done or not by the bolted on extra brackets.
- Hoodzy
I think it's canada only?? Plus it doesn't say they'd replace the springs. they'd only put on brackets to make sure a broken spring didn't puncture the tire.
- umcamara
Well everyone who's taken advantage of the recall has had their springs replaced. Ryan for one...Hoodzy wrote:I think it's canada only?? Plus it doesn't say they'd replace the springs. they'd only put on brackets to make sure a broken spring didn't puncture the tire.
- Ryan
They will replace broken springs, obviously. What kind of retarded recall would leave the broken part? what if toyota only installed a big spring on their flucked pedals?
They replace the springs, put on the safety bracket, and will not replace your tire(s)
MX-3 SUSPENSION:FRONT:SPRINGS:COIL SPRINGS Recall – ID# 19979
Description
VEHICLE DESCRIPTION: PASSENGER VEHICLES ORIGINALLY SOLD OR CURRENTLY REGISTERED IN THE FOLLOWING STATES: CONNECTICUT, DELAWARE, ILLINOIS, INDIANA, IOWA, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, NW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, WEST VIRGINIA, WISCONSIN, AND WASHINGTON, DC. IN AREAS WHERE LARGE QUANTITIES OF ROAD SALT ARE USED, CORROSIVE PITS CAN DEVELOP ON THE SURFACE OF THE FRONT SUSPENSION COIL SPRING. REPEATED USE CAN EVENTUALLY CAUSE THE COIL SPRING TO BREAK AND A TIRE COULD BE PUNCTURED FROM CONTACT WITH THE BROKEN COIL SPRING.
Consequence
THIS CONDITION INCREASES THE RISK OF A VEHICLE CRASH.
Remedy
DEALERS WILL INSTALL A GUARD ASSEMBLY WHICH WILL PREVENT THE BROKEN COIL SPRING FROM CONTACTING THE TIRE. IN ADDITION TO PERFORMING THE RECALL CAMPAIGN, MAZDA IS EXTENDING THE WARRANTY COVERAGE ON THE FRONT COIL SPRINGS FOR THE LIFT OF THE VEHICLE. IF OWNERS HAVE ALREADY PAID FOR THE REPAIR OR REPLACEMENT OF THESE FRONT COIL SPRINGS, DUE TO ROAD SALT DAMAGE, MAZDA WILL REIMBURSE THESE OWNERS FOR REASONABLE EXPENSES.
Potential Units Affected
25000
Notes
MAZDA (NORTH AMERICA),INC
Thats an american version, but its all the same.
Description
Consequence
Remedy
25000
Notes
- Hoodzy
wow.. i'd hate to see the condition of your car if rust is going to destroy your springs.
- Ryan
Did you read it?
It sits in the spring base. You can't exactly wash in there.
