Everything is working fine expect the low beams. High beams, dash, turn... all ok.
Low beams work randomly, sometimes i turn on the car and they work sometimes they don't. Switching them on and off repeatedly doesn't seem to work, neither turning on and off the high beams.
I've searched and found it could be:
bulbs (sometimes work, so i'm guessing they are ok)
fuses (checked the main fuse block in the engine bay, all seem ok)
relay (?)
Well looking in the manual it seems to me that the headlight relay would be the one marked red. I swapped the connector with the green marked one, no change. I'm a bit lost now...
I hear clicking, but i guess it could be damaged anyway...
Any ideas?
