Obd 1 or 2
Obd 1 or 2
Hey just quick question did any of the 94 mx3 come obd 2 or no
- solo_ryder
Re: Obd 1 or 2
Most 94's if not all of them are obd1, some 95s are obdII and 96s are obdII. An easy way to tell is to check the ecu.. Pop off the pass side footwell cover and look at the ecu plugs. If there are 3 total then its a obdI if it has 4 plugs its a obdII. ObdII will also have a diagnostics plug under the dash
Re: Obd 1 or 2
K thanks dude
- Ryan
Re: Obd 1 or 2
assuming you're 5 speed, that is.
- DeepBlueMX3
Re: Obd 1 or 2
Hi there!
Does it fits to obd I mx3's ? look at link: http://cgi.ebay.com/ebaymotors/Equus-31 ... 0518742966" onclick="window.open(this.href);return false;
- DeepBlueMX3
- umcamara
Re: Obd 1 or 2
Man. You don't need that even if it did work. There's a procedure for reading OBD-I codes involving a paperclip and your ignition key. Search it up on here.DeepBlueMX3 wrote:Up! No one knows?????????????????
And besides that, did you read the product description? It doesn't even mention MX-3's or the engine. Come on man...
- DeepBlueMX3
Re: Obd 1 or 2
Hi man, unfortunately brazilin imported MX-3 didn't come with this auto diagnosis system...umcamara wrote:Man. You don't need that even if it did work. There's a procedure for reading OBD-I codes involving a paperclip and your ignition key. Search it up on here.DeepBlueMX3 wrote:Up! No one knows?????????????????
-When you jumper TEN and GND , any engine check light turn on...
![Crying :crying:](./images/smilies/crying.gif)
-that's way, I still need to know what cheep obd thing fits to my belowed mx3...
Thanks for your attention!
- umcamara
Re: Obd 1 or 2
What year is your car? If jumping TEn and Ground doesn't work, and it's OBD-I, I can't see any OBD-I reader working. If your car is '95 or newer it may be OBD-II, but I believe that was only mandated in North America. In Brazil it may not have been.
- RS_OBD'oh_2
Re: Obd 1 or 2
that doesn't seem right at all.
Re: Obd 1 or 2
DeepBlueMX3 wrote:Hi there!
You need to buy a reader that is compliant with your car. If yours was obd2 you need to buy one of these.
* J1850 PWM (Generally ford vehicles manufactured between 1996-2005)
* J1850 VPW (GM & some chrysler vehicles)
* ISO9141-2 (Most imports)
* KWP2000 (Saturn and some imports)
* ISO15765-4 (CAN) (most 2005 & newer vehicles)
That one you asked about is no good for your car.
- DeepBlueMX3
Re: Obd 1 or 2
My car's year are 1994/1995 dohc 1.6,here we have the same model until the 1998 year, from official importers, I belive that only extra-official imports from USA and Canada come's with this diagnostics system, certainly for cheep the cars sold here, they come withless
air bags and abs brakes...(1.6 dohc), only the 1.8 v6 comes with it, but they are very rare in my country.I guess that obd I reader at the first link that I wrote can works on mx3...
- Ryan
Re: Obd 1 or 2
if you have the diagnosis box with TEN and GND in it, you must have the self diagnostic feature. without self diagnostic, it wouldn't give you codes on a reader anyway. It doesn't make sense that you wouldn't have it...
Does the CEL work at all? maybe someone went to the effort to remove the bulb for you.
- umcamara
Re: Obd 1 or 2
Plus the reader that you linked to will not work regardless. Nowhere in the product description does it say Mazda MX-3 or 1.6L or 1.8L. It does, however, list the vehicles that it does work for, which aren't this one. Why is this so confusing for you??
- DeepBlueMX3
Re: Obd 1 or 2
- Ok, certainly my car must have the diagnosis system, but not in the cluster with a code error check engine light...
-I found this home made check engine on youtube, I'll try it. What do you think, it can works?
http://www.youtube.com/watch?v=IU4uOHatUR0" onclick="window.open(this.href);return false;
