Anyone have any suggestions on "un-hooking" the ECU from the harness?
I could do it, but it takes like 30mins. Should I add some type of lube or vaseline to make it easier to unhook?
Why is taking out the ECU such a pain in the a--?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- Dali
Re: Why is taking out the ECU such a pain in the a--?
why is it taking 30 min to push three clips on the harness and pull them out. four ten mil nut/bolts. two push clips on the covers. this is pretty easy and only should take five minutes tops. adding lube on the clips to make it easier?????
1993 White gs klze.
- Ryan
the harness clips can be in there pretty tight sometimes. I sometimes use wide jaw pliers and grab it on the sides to wiggle it. Better than yanking on the wires.
Yeh, if the connectors are tight, it can be a pain. Usually using a large flat head screwdriver to slightly pop them out while pressing on the clip can work fairly well. Once you take it out a few times, it's becomes easier. First time it did take me quite a while, now I can swap ECUs in 5 minutes.
I've swapped out my ecu about 8 times in the past 6 months and it's still a PITA!
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
