miata tranny swap??
GIjoe
miata tranny swap??
would a 1990 miata tranny fit into a 93 mx3? 4 cyl 5 speed
did you know that my mx-3 thinks....?
- Ryan
Re: miata tranny swap??
No, man. FWD vs RWD. totally different transmissions.
If you want a tranny upgrade, get a G series out of an Escort GT, or any other car with a BP.
GIjoe
RIGHT!! duh, why didnt i think of that.... hahaha I found one on craigslist for 300 dollars with a short shifter.... oh well... thanks man...
- Ryan
The transmission had a short shifter?
That's not right. lmao! I guess 2nd, 4th and reverse all the way!
GIjoe
so I guess the tranny the guy has is FROM an mx3... so it all works out
275 for the tranny with the short shifter
its got 114 miles on it.... not to bad I'd say
- Ryan
What? Man, transmissions are like $100 TOPS. short shifters are like $50. You're getting ripped off
GIjoe
really?! where can I get a tranny for 100 dollars??? I have done alot of searching and 275 is thee lowest i have seen so far...... if you know of a place to get one for 100 bucks then please, dont keep it to yourself!!
- Ryan
I can pull them myself for $75 at my local yard.
Any 323, protege, escort... any of those with a B series motor have a tranny you can use. They're dime a dozen.
IF the tranny actually has 114 miles on it...not 114K miles...$275 would be a very good deal on a recently rebuilt tranny. However for a USED tranny with 114K miles, that is just on the high side. You are paying for the guy to pull it and stuff and Ryan's right...you can pull one yourself from any 323, Protege, Escort GT of the right year at your local DIY wrecker. My wrecker charges $125 for trannies. I would not pay more than $200 for a pre-pulled tranny. BArter with the guy...you might be able to do better.
Does it actually have one hudred and fourteen miles on it? Can that be proven?
