6 speed for a 4 cylinder?
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
GIjoe
Post by GIjoe »
I own a 93' MX-3 that is in need of a new transmission and I was wandering if it would be smart or even possible to put a 6 speed manual transmission into it? if so what other factors would come into play?
did you know that my mx-3 thinks....?
Ryan
Re: 6 speed for a 4 cylinder?
Post by Ryan »
thats a terrible idea. Bell housings are different, axles are different, speedometer is different,
Wait. 6 speed? where would you get that? how would you geet it to fit? Its not like they make universal units. Ha, I was giving you the benefit of assuming you had meant 6 cyl transmission.
No, doens't work, if it did, we would have done it long ago.
pox
Post by pox »
Why would you want to shift so many times. We burn through the gears now as it is.
Took the bp+t out of the mx and swapped it into a 95 escort wagon. ;)
jmdearras
Post by jmdearras »
The 4 cyl is more torque/hp peaky, more gears would let you stay in that RPM range longer.
Ryan
Post by Ryan »
Who cares, where are you going to get a 6 speed that makes to these engines?
_-Night-Shade-_
Post by _-Night-Shade-_ »
Found this from another thread, for V6s though:
http://www.xtremethings.com/F40_Transmi ... splant.htm" onclick="window.open(this.href);return false;
GIjoe
Post by GIjoe »
hahahaha!!! I was just curious.... thanks though :)
does anyone know where to get a good used 5 speed tranny?
Ryan
Post by Ryan »
scrap yard, member close by.... hundreds of options, transmissions are easy to come by
Any B series motor...
GIjoe
Post by GIjoe »
rite! im gonna have to get searching.... thanks :)
GIjoe
Post by GIjoe »
cant the protege 5 speed trannys be swapped into the mx3's?
Ryan
Post by Ryan »
Only B motor series proteges (look like 323)
And the GT (BP)s come with G transmissions, which work, but require new stuff like axles and I believe spindles...
GIjoe
Post by GIjoe »
ah I see well then im gonna have to get an mx3 tranny cause I dont have the cash to do anymore then the tranny right now.... thanks for the info
Ryan
Post by Ryan »
or protege, 323.... anything that has a motor that looks like yours, or the other MX3 4cyl motor.
nos92mx3
Post by nos92mx3 »
GIjoe wrote:ah I see well then im gonna have to get an mx3 tranny cause I dont have the cash to do anymore then the tranny right now.... thanks for the info
Where are you located?
Ive got a good f series tranny i could sell
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
GIjoe
Post by GIjoe »
Hey do you still have that tranny for sale? I am in Goshen Indiana 46526
thanks
Return to “Transmissions”
