millenia s injectors
- SpatialTerror
i know for a fact i have a millenia 2.5 which im fine with. still hauls a--. but i am planning on putting a turbo on my car. and i was wondering how to tell if i got the millenia s inlectors?
93 GS-R with crank pulley racing clutch and flywheel, magnaflow cat back exhaust, short ram air, 12" rockford fosgate p2 subs, on a amp 500rms, jvc touch screen deck.work log --->http://mx-3.com/phpBB3/viewtopic.php?f=46&t=75217
92 RS with lowering springs, and body kit.
SpatialTerror
SpatialTerror
- JWMX3
Re: millenia s injectors
you dont. Millenia S injectors only came on the 2.3 liter Miller cycle engine
yours will be blue tops, same as all the 2.5s
![Image](http://img40.imageshack.us/img40/7481/avatarmx.png)
- SpatialTerror
would they handle 4 to 6psi. if i was running a turbo?
SpatialTerror
SpatialTerror
- JWMX3
At 5psi the stock injectors would need about 80 psi fuel pressure and would be near maxed out.
You don't seem to know much about forced induction, i'd suggest to pick up this book http://www.amazon.com/Maximum-Boost-Tur ... 439&sr=8-1
Especially the Fuel Injection chapter will give you everything you need to know as far as calculating fuel pressure required if you plan on running low boost on the stock ecu with an FMU or adjustable fuel pressure regulator. Also will help you with fuel pump requirements, FMU ratio, intercooling etc.
It covers everything very well for the beginner, GL
My stock injectors max out at 8 psi. Anything over 5psi you are risking a stuck injector = boom
I have been maxing my injectors for 3 years now tho.
Millenia s injectors + megasquirt = win on a turbo application.
-hec
- bbunkerc397
Is their a Supercharger book too? ![Smile :-)](./images/smilies/icon_smile.gif)
1996 MX-3 KL-ZE with Eunos 800 IM, factory side skirts,. "Owner since 2001 my 14th year"
1992 929s 20B-REW Lowered, 17" chrome Millenia rims, custom black interior. "13th Owner 9th year"
2006 Chevy HHR LT "Bought Brand New - East Side Chevy" Sold to my Dad
