wiring for gauges
- 96chris
wiring for gauges
hey im tring to wire in the power wire for my new gaudes i bought and i cant find the wire that is the power to the original lights. there are 3 clips that plug into the back of the entire cluster unit.. 2 white ones and one black one. i found out that one of the wires that is in the black clip powers the original lights in the cluster. (by plugging in each one and seeing which one made them work) do you know where i could find out which dam wire it is?? i really need to get this done so i can drive lol
96 RS DOHC
-lowered
-glow gauges
-lowered
-glow gauges
- solo_ryder
Re: wiring for gauges
I would wire them into the dimmer, on the left side of the dash behind the wheel. Get a fricken multimeter from where-ever and test each wire to see which one gives u 12v of power, use that wire.
- 96chris
so there mill be multiple wrirs that go into the dimmer, and wire it into one of those? why wouldnt i wire it into the wire that powers the main bulbs??
96 RS DOHC
-lowered
-glow gauges
-lowered
-glow gauges
- Ryan
Don't question the man who is answering your question. If you know what you want to do, do it, and don't ask.
The dimmer has a 12v, a ground, and obviously, the output from the dimmer to the dash harness. You can either put your gauges on the 12v wire for constant power, or put it after the dimmer, and maybe ruin the gauges (LED, incandescent, or ??? backlight, or powersource)
The main reason to put it in the dimmer circuit is so you don't have to tool around with a switch so it doesn't drain your battery, because the dimmer is worked into the ignition.
Oh, I just re-read your post. Put your cluster back together, and wire it to the dimmer switch, not the cluster. Silly head.
If these are gauge faces, like fuel/temp speedo and tach, remove the stock bulbs. Don't need them, and it should level out the load on the circuit.
- solo_ryder
Yea, the dimmer is optimal as it goes on with the lights, which is when you want your gauges to light up right? This is where I hooke dup both of my AEM digi gauges and I didnt have issues.96chris wrote:so there mill be multiple wrirs that go into the dimmer, and wire it into one of those? why wouldnt i wire it into the wire that powers the main bulbs??
- 96chris
the gauges come with its own dimmer.. should i just scrap that dimmer and just use the one thats in my car?
96 RS DOHC
-lowered
-glow gauges
-lowered
-glow gauges
- Ryan
I'm going to assume that you have some ebay guages. I thought they came with very clear instructions, but...
Do not scrap that dimmer, it isn't the same at all. The ebay guages don't work on straight 12VDC. They have a power source. They must be used seperately, do NOT try and integrate them by cutting and splicing wires that you're not meant to.
Here it is, nice and simple.
Remove the dimmer switch (that fun rolly wheel on the left of the steering wheel that makes all the lights change brightness)
Take the clip out of the back, it should be 3 whole wires. One is ground, one is +12V and one is the output to the dash harness(maybe 5-12v depending on position).
Discover these with a multimeter, or looking in online manuals http://www.mx-3.com/manuals/index.php?f ... 0Manual/Z/" onclick="window.open(this.href);return false;
Tap into the +12V one (keep original circuit though) as the main power for the ebay gauges. Set the powersource somewhere (so it doesn't rattle around), and ground its ground wire somewhere (doesn't matter, ground is ground)
Install the gauge faces, and run those wires back to the powersource (clip connectors?) while you're installing, remove bulbs from the dash. Just the illumination lights, not the dummy lights.
Put everything back together, connect everything, and use the dimmer that comes with the powersource to change new gauge brightness. Use the stock dimmer to change the HVAC brightness.
/End
/End
Yes and since it's going up to a scortching +4 tomorrow you'll enjoy working outside for a change.
or you could drop the wires down to the light on the cig lighter! then you have a 12v and a 0v simple cut and test only 2 wires connect them in and enjoy
- 96chris
so for the cig lighter its only 2 wires,, one 12v and one 0v. splice into the 12v wire and attatch my red power wire into it, the grond the ground
96 RS DOHC
-lowered
-glow gauges
-lowered
-glow gauges
- Ryan
Why don't you just do it properly... I'm done with this thread.
i find it safer that way easyer to get to, and less wires to risk snagin or breaking
- Ryan
On all of those dangerous, hot, moving parts back there.... oh wait, the cig lighter DOES get hot
