Mi|<e - 94 GS BPT dyno tuned
Re: Mi|<e - 94 RS BPT
edited: do not mod speedo internal bits.
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- Limegreen mx-3
Damn 94+ MX-3's nothing but trouble.. The mechanical version is so much simpler using the kia trans.. I am going to have to keep that in mind when mazda20 upgrades from his f-series to kia trans.. The speedo gear part i mean.
Just to note even though the trans is beefier than that of the mazda g-series the stock diff is still a weak point. Already grenade ed a diff off the line at the track that wasn't fun. It can handle a bit more punishment in the 2 years i have been using it.
In all great worklog u got going on. Tidies task reassembling a manual trans been there more than once.
- mx-3_4evr
s--- I have to do this mod now lol
- Limegreen mx-3
You gotta love the 94+ MX-3 'smx-3_4evr wrote:s--- I have to do this mod now lol
I cant stress enough the importance of good tools, flare nut wrenches especially:
Speedo gear and 75W90 GL-5 fluid are in:
Also plumbed in the clutch line, corksport line included:
Now what I need is a vacuum bleeder for the clutch line.
Who knew?
Who knew?
1994 MX-3 RS
Yep that speedo idea doesnt work well so don't do it. Just
convert the unit to cable driven. I picked up a 91 Protege GT
to sacrifice for the good of the Mx-3.
The engine I haven't decided entirely what to do with but I suspect
I'll be rebuilding it high compression NA and making a 'plug and play'
BP to sell to a fellow Mx'er.
1994 MX-3 RS
- Evo_Spec
i would be interested in that very muchMi|<E wrote:The engine I haven't decided entirely what to do with but I suspect
My holy-sh*t meter went off today - im disassembling the
BP for a plethora of parts for the MX and other things and
I get to taking off the valve cover. Here is what I find:
Now either someone may have had this rebuilt already or
its been babied through its 255000 kilometers of life. My
freshy head looked about like that after 10000 kilometers.
1994 MX-3 RS
- Ryan
wow. Did you say you wanted to sell that motor...?
Im not sure what I'll do with it yet, other than rebuild
it and replace all the worn bits.
Heres inside:
Heres inside:
1994 MX-3 RS
- Evo_Spec
Evo_Spec wrote:i would be interested in that very muchMi|<E wrote:The engine I haven't decided entirely what to do with but I suspect
on a side note, i wont be back in calgary till june =/
*edit* the actual day of return is may 15th
Ive been busy with the white protege this winter, harvesting it for
parts.
I also took the time to get rid of my RS steelies and replace them with the
aluminum protege 14" rims. They are for winter and have bridgestone blizzaks
on em.
parts.
on em.
1994 MX-3 RS
- Evo_Spec
When's your turbo going in?
can't wait to see that and the progess to it
- mx-3_4evr
you know what I just figured out, you can use the electric speed sensor out of a kia sephia or a 2nd gen protege I think. I'm going to give that a try
Fitment begins:
turbo lines / FMIC pipes and exhaust are all thats left now
Also here is my noise maker:
1994 MX-3 RS
