installing a resonator
Finch
Post by Finch »
i have a 2 inch stainless exaust from the downpipe back with a magnaflow cat and magnaflow muffler... but my car doesnt sound the way i want... if i had a resonator installed in between the cat and the muffler would it make it sound better? like my exaust is loud right now.. and i do like it being loud... but its not the right kind of loud, i donno its hard to explain.. any input would be great... thanks!
----"A Real Car has 3 Pedals"----
2007 Satin White Pearl Subaru Wrx 2.5L
2007 Blue Subaru Impreza Sedan 2.5I Special Edition - Sold
1996 Black Mazda MX-3 RS - Sold for Part
Re: installing a resonator
Post by wytbishop »
Adding a resonator will change the exhaust note, but whether it will make it better or not is difficult to know. Magnaflow stuff is good quality but it is not quiet in my experience.
4gotn
Post by 4gotn »
resonator will disrupt the sound like you want it to
good luck finding one though
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
Finch
Post by Finch »
lol i wont be able to find a resonator? or i wont be able to find an actual magnaflow resonator..
4gotn
Post by 4gotn »
wont be able to find a decent resonator for cheap that wont require you to chop up your exhaust >_<
you could get a factory one but its obviously too small
SOME aftermarket shops carry them but their too expensive :/
i just installed a glass pack on mine ^_^
i notice you have a 1.6 dohc like i do
all i have is straight pipe with the glass pack and i get compliments on the sound of the exhaust all the time
does your magnaflow have one of those fart canister resonator tips on it?
Evo_Spec
Post by Evo_Spec »
uhhh, you can get cherry bomb resonators at canadian tire for like 40 bux, they helped my friends exhaust on his talon, it sounds amazing now
4gotn
Post by 4gotn »
http://www.cherrybomb.com/products/glasspack" onclick="window.open(this.href);return false;
thats the same thing i have on my car
its really a glass pack
it works almost the same but im not sure how it would sound with your magnaflow muffler
wont hurt to try it but be prepared to do some chopping
Finch
Post by Finch »
yea i figured i would have to chop the exaust... but im fine with it as long as it's done properly.. my buddy has a resonator before his muffler on his integra and it sounds amazing.. thanks guys for your help!
4gotn wrote:wont be able to find a decent resonator for cheap that wont require you to chop up your exhaust >_<
im not sure if my magnaflow has the fart canister tip on... its a stainless dual tipped muffler.. all i know is its really loud.. lol
4gotn
Post by 4gotn »
if its a dual tip it may not but having the resonator in the muffler will give it that raspy bumble bee sound
i would try the glass pack and then if you dont like the sound then just keep the old pipe and put on something with a deeper sound like a dynomax or flowmaster
the b6 dohc with straight pipe sounds about like a 3.0 v6 for some reason, just to give you an idea of what your shooting for
