MODIFIED TO RUN ON E100! Stock for stock is DOES NOT give more power. It has lower energy density. The E100 engine HAS to be higher compression to get better mileage/power, and higher compression is more efficient.Inodoro Pereyra wrote:Two identical SUVs, one with a gasoline engine, the other one with the same engine modified to run exclusively on E100.
Shell Gasoline?
- onlytrueromeo
Re: Shell Gasoline?
- Inodoro Pereyra
Re: Shell Gasoline?
Of course it's modified to run E100! Why would you want to run 135 octane fuel on an engine designed to run 87 octane?onlytrueromeo wrote:MODIFIED TO RUN ON E100! Stock for stock is DOES NOT give more power. It has lower energy density. The E100 engine HAS to be higher compression to get better mileage/power, and higher compression is more efficient.Inodoro Pereyra wrote:Two identical SUVs, one with a gasoline engine, the other one with the same engine modified to run exclusively on E100.
You would have exactly the same problem if you were to use 87 octane gas on an unmodified Ford model "T", designed to run on 28 octane gas! Don't you think that's a bit of an unfair comparison?
The point is that with ethanol you CAN run a higher compression, while with gas you can't.
Diogenes of Sinope.
Diogenes of Sinope.
- mitmaks
Re: Shell Gasoline?
Inodoro Pereyra wrote:Nope. Engineers at a Swedish car manufacturer (I don't remember if it was Saab or Volvo) did a comparison a few years ago. Two identical SUVs, one with a gasoline engine, the other one with the same engine modified to run exclusively on E100. The E100 engine showed more power, and a 18% increase in gas mileage.onlytrueromeo wrote:Ethanol is only good for those who have higher compression engines or are running big turbos. It has been proven to lower gas mileage across the board, so the 10-20% ethanol sucks, unless it is reducing the price enough to compensate.
E85 or 100% ethanol would be good if the majority of us could take advantage of it...but since we don't all have turbo's or 15:1 CR, we're just losing power and mileage.
If you want to keep your engine's compatibility with gasoline, your gas mileage will go down, but if you modify your engine to run ethanol exclusively, due to the increased thermal efficiency of higher compression engines, the mileage goes up.
A 15:1 compression ratio is just a shave away. You don't need a specially designed engine.
You can either deck the block and head enough, you can use domed pistons, or you can get a crankshaft with a longer stroke. Of course it will take some experimenting, but so does any other modification you want to do on an MX-3.
EXACTLY, that's whole point is their engine was MODIFIED. We're talking about stock here, many of us still have stock k8's that run as daily drivers. Pure E85 or even 10% does not belong in my stock mx-3 or any other car for that matter as they were not tuned to run on ethanol.
If you want you can run E85 on your race car, don't run it on your stock car. Case is closed.
- onlytrueromeo
Re: Shell Gasoline?
My point is that ethanol is pointless unless an engine is designed for it.
Further posting in this thread is useless for me...my arguments are just going in circles.
- Inodoro Pereyra
Re: Shell Gasoline?
No, the whole point is that ethanol is a better fuel than gas on an engine that's able to handle it, and that modifying a stock engine to run ethanol in any concentration is stupid easy.mitmaks wrote: EXACTLY, that's whole point is their engine was MODIFIED. We're talking about stock here, many of us still have stock k8's that run as daily drivers. Pure E85 or even 10% does not belong in my stock mx-3 or any other car for that matter as they were not tuned to run on ethanol.
E10 is a reality in most of the U.S., and it's bound to become a reality worldwide in the near future, whether you like it or not. ANY stock engine can run E10, and most stock engines can run E20 without modifications.
I would NEVER be dumb enough to waste ethanol on any concentration higher than E20 on a stock engine. Not because it'd damage the engine, but because it would be like putting lipstick on a pig.
Diogenes of Sinope.
Diogenes of Sinope.
Re: Shell Gasoline?
HEY! It makes spiderpig feel sexy.
![Image](http://i659.photobucket.com/albums/uu316/93vtecklr/ClintsSig2.jpg)
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
- Inodoro Pereyra
Re: Shell Gasoline?
Diogenes of Sinope.
Diogenes of Sinope.
Re: Shell Gasoline?
ya whassup miss piggy, i bet your hoo-haa smells like bacon.
- mitmaks
Re: Shell Gasoline?
![Image](http://www.the-wild-flower-trilogy.com/images/SEXY%20PIG%20-%20DA%20-%20THANK%20YOU.gif)
Re: Shell Gasoline?
Absolutely fantastic. That image will serve me well/haunt me those lonely nights at sea.
- Inodoro Pereyra
Re: Shell Gasoline?
Diogenes of Sinope.
Diogenes of Sinope.
Re: Shell Gasoline?
ever since i put it in my tank. my car quit sputtering. on take off and steady speed.mitmaks wrote:you think so or you know so? Really, we need proof it works. You can't really says "ya it works" unless you have data to prove it.Mx3Kid16 wrote:Yeah thats it. "Nitrogen-Enriched"
i seriously thinks it helps.
? teach me how to collect that data.
CF Hood, Kenwood everything, 2.25 catback exhaust, H&R Springs, F&B Strut bars
My worklog: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=68856" onclick="window.open(this.href);return false;
Good afternoon from the biggest Douch around;D
- mitmaks
Re: Shell Gasoline?
Mpg data would help. I do get sputtering once in a while also, even though I use same gas station every time. Guess what they do not have any nitrogen advertised. It really depends on your car, it has mind of its own. Maybe you have a clogged filter or your pump is going out, who knows...Mx3Kid16 wrote:ever since i put it in my tank. my car quit sputtering. on take off and steady speed.mitmaks wrote:you think so or you know so? Really, we need proof it works. You can't really says "ya it works" unless you have data to prove it.Mx3Kid16 wrote:Yeah thats it. "Nitrogen-Enriched"
Re: Shell Gasoline?
well when i filled it up with chevron... it started sputtering again...
bad fuel pump?
bad fuel pump?
- solo_ryder
Re: Shell Gasoline?
Could also be a bad fuel pressure reg, or a bad injector
