[WTB] Ecu for a 95 klde( ajax/toronto ,canada)
not sure what i need kl36 or kl31 any help?
- solo_ryder
Re: WTB
Fix the title.
Have you checked the wreckers or on probetalk?
Re: [WTB] Ecu for a 95 klde( ajax/toronto ,canada)
KL31 and KL36 are KLZE ECU's, not KLDE. Should still work fine, but the idea combo would use the ECU and VAF from a DE
- solo_ryder
Well how bout abit of background info first? Is the motor a 95? Is the motor in a 95 probe or in a mx3, what year mx3?
You want to make sure the ecu is compliant with your wiring harness, if you have a 92-94 mx3 you proly wanna use a kl01, kl07 or kl48 ecu. There obd1 ecus and then use the kl02 airflow sensor with those ecus
Hey im from ajax too! whats your car look like maybe ive seen you around
92' Red GS - RIP
93' Black Miata LE
93' Black Miata LE
