i don't see why it would be any different than the DOHC. if i'm not mistaken Corksport was going to build headers that would fit both. but i might be mistaken. i would like a 2nd opinion, as i'm about ready to buy a turbo to put on my snail. and would like to know if i need to swap heads first or if it'll bolt up. thanks.
'91 MX-5 with plenty of mods, '94 DOHC MX-3__HP Design muffler, glasspack, custom intake (superk's idea), KYB GR-2 shocks, projector headlights, GS front end, Rear Disc brake conversion, swaybar and tie bar, and lip spoiler, JDM mazdaspeed full-length side skirts,
the sohc and dohc use different exhaust bolt patterns as for the intake side as well. Where do this idea's come from??? Now u know if the exhaust side where the same more people would have used the turbo manifold from the b6T on a sohc. Like they do for the B6DE..
wow, i did not know that they had diff bolt patterns. i had looked through the forum, and in one of the threads, where the SOHC dude wants to swap to a DOHC off a capri, and someone else had told him to keep his own IM so he had the intake to the side, not "over the valve cover" like the one in the capri. i might have misread it... if i did, i apologize.
and Advance Auto also showed me an exhaust mani gasket and it looked just like the DOHC. i've got a SOHC, but got plenty of miata parts, so i had a personal interest.
ooh, and on the SOCH-DOHC swap threads, i haven't seen anyone pointing out the fact that you'd need a new exhaust mani.
So... I guess I am SOL until someone decides to make a manifold fit for turbo huh... Do they make a Probe 2.0 Turbo Header? I know after port matching that this header will work...
I don't know how people can never find anything?
This is where I got my dohc mani kit. It has a couple extra stud holes in it that I did not use on my dohc. This may work for the SOHC. It does end up looking the same as turbomazdas.
BTW. hope you got some skills.
On page 1 of my WL, you get a shot of the flange bolt pattern. Compare it to your exhaust gasket and then order the mofo if it's correct http://www.mx-3.com/phpBB3/viewtopic.ph ... 74&start=0" onclick="window.open(this.href);return false;
I'm sure the question has probably been answered elsewhere... but would the 323 turbo manifold fit the B6-ME? Or am I still out of luck. I read an article from a guy that built up a B6-ME and mentioned something about using the 323 turbo manifold.
