where do i get this piece, seems that im missing one.
Were do these plugs go????
This seems to be a coolant line that runs to the back of the motor and is next to the "in" line for fuel, by the fuel filter
This one sucks " the ripped rubber line" on the end of "mystery line" what is the line...power steering?
thanks in advance for the help.
Need a little HELP
- MAZDA SPEED MX-3
- msd-supermx3
Re: Need a little HELP
ok i take it you did a KLZE swap????
if yes. the
1st picture is a plug for an EGR as cuz i got one too and my buddyes is pluged there.
2nd--- I got one too. dunno what it does.
3rd--- ?????????????????????????
4th--- if i remember correctly that actually might be a temperature sensor. a ZE has one less or one more???? (someone back me up on this)
5ht--- ZE had an auto tranny. so it was using coolant. I had one, i blocked mine off. (Or could be an A/C line?)
6th- what side is that on???
if yes. the
- onlytrueromeo
4th is either a coolant sensor plug (some ZE's have 1 others have 2, k8 has 2...if your ZE has 1, you can swap filler necks or drill+tap a hole for sensor) or it could be your crank angle sensor (I think thats what it is) comes up from down by where the oil dipstick is..my first ZE didn't have it so I swapped it from my k8.
Cant remember what 3rd ones are for, but you should be able to connect them if you look hard enough - I remember being confused about them, but did end up finding plugs. Its dark out otherwise id go outside.
- onlytrueromeo
6th looks like a fuel line dude...since that IS your fuel filter right there. Its not connected right but I cant tell for sure since I need a different angle.
Look in the shop manual, a quick look found this but there are better images if you keep looking.
http://mx-3.com/manuals/showimg.php?fil ... F2-115.gif" onclick="window.open(this.href);return false;
I'll check mine too, too dark right now. Tomorrow.
- MAZDA SPEED MX-3
thanks guys i appreciate the help. been away from the car due to winter. ill update my findings on what i figured out for sure so far tomorrow.
- MAZDA SPEED MX-3
