zero spark? KLZE
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
studboy13
zero spark? KLZE
Post by studboy13 »
So I was redoing my radiator coolant lines and i happened to spray coolant pretty much everywhere above the tranny. then the car stopped sparking, still turned over and everything. so i assumed my coil shorted so i went out and did the HEI mod. everything is hooked up correctly and now im back to where i started. still no spark. what should be the next thing that i check? any and all help would be greatly apprciated.
92' GS KLDE, Cosmo Racing UDP, CAI, AWR Motor mounts solid, Pheno spacers . interior gutted, MTX Swap, unorthodox racing flywheel/ 4 paddle clutch. short shifter, SRD bushings, brembo cross-drilled rotors, corksport racings red stainless steel lines. megan escort springs, zx2 sturts, whiteline rear sway bar, rear strut bar.
Re: zero spark? KLZE
Well, if the coil is gone and you did just the HEI, you still need to do the external coil along with the HEI. HEI just replaces the ignitor
studboy13
Post by studboy13 »
sorry for not specifying, i did the external coil as well
What did you use for disty? You put a tower on your stock K8 disty cap, you use a PRD cap or you using a ZE disty?
studboy13
Post by studboy13 »
tower on the stock K8 cap
its in there pretty good
studboy13
Post by studboy13 »
can someone please help me
this is killing me
Try disconnecting the neg. from the battry and depress the brake pedal for 15 secs. I had to do that to reset my ECU. You may of shorted out the system with the coolant
Return to “Engine Electronics/Tuning”
