Hi, becouse of oil consumption I changed my engine. My old one was a 97 1.8 and the one
I put in is a 91 1.8. I know there are some minor difrences but I cant imagen that there should be a problem.
Now my problem is this; Everything I can think of is hooked up and pluged in.
The car crankes and turnes over but I dont seem to get any sparks, so it wont start.
Anything anyone can think of that I forgot or what can be the problem? (Solved)
Also, the the clutch pedal wont return when I press it inn, anyone got an idea on this? (solved)
Regards
Norwegian81
Changed engines from a 97 to a 91 wont start (solved)
- marcdh
Re: Changed engines from a 97 to a 91 wont start
Are you using the distributor that came with your car? Make sure you do the wiring changed over the years.
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
I noticed that they where difrent but I dident think that it would mather.
I'll try changing it over tomorrow, tank you![Wink ;)](./images/smilies/icon_wink.gif)
Also any takers on my clutch pedal problem?
Regards
Norwegian81
Regards
Norwegian81
Hey not to jack the thread.. but WHAT do you NEED to get an ob2 engine running in an obd1 mx3? We want to keep theobd1 set up, just change the disty? and the sensors out?
-hec
Hi hgallegos915, I'm not sure what the difrence is with the OBD1 and the OBD2 I would recon it's the alternator like marcdh said, cant say about the sensors. Problem is that in Norway, as far as I have managed to find out, all the engines ranging from 91 to 98 came with OBD1.
regards
Norwegian81
regards
Norwegian81
Ok so I've changed over the distributor like marcdh said (thanks
) and it starts, the clutch pedal broblem also got solved by airing it.
But when i started it it ran fine, went for a test drive and there were a massive power loss and it were stalling (dont know if it's the right word). Seemed like there where timing isues maybe.
Will the engine start if I put the Distributor on 180 degreas wrong?
What otherthings can be the problem? (Solved)
Regards
Norwegian81
Regards
Norwegian81
Re: Changed engines from a 97 to a 91 wont start (solved)
How did you solve the timing problem?
-hec
hgallegos915: I dont know if it where a timing problem or not, I took the distributor out, changed the spark plug wires and put it back in. The engine seems to be mutch beter now, however it still seems to be lacking some power becouse it still sudently givs more power out. I think I need to just fine adjust the distributor alittle. I will ask some of the car mechanics at work tomorrow.
Regards
Norwegian81
Regards
Norwegian81
