Oil Filter Upgrade
- umcamara
Oil Filter Upgrade
There's a thread in the V6 forum about bigger oil filters that will thread onto the K8 and KLZE blocks. Just wondering if anybody knows that actual upgrade filter for the B6DE.
Ryan seems to think it's the Miata or Millenia filter. Anybody know for sure? A search doesn't really reveal anything.
- Inodoro Pereyra
Re: Oil Filter Upgrade
The oil filters for the B6-BP engines are, to the best of my knowledge, all the same: Fram 6607, Purolator 14612, Mobil 1 M1-108...
The oil filter for the K8-klze-de engines are Fram 7317, Purolator 14610, Mobil 1 M1-110, K&N HP 1010, which is a few millimeters bigger than the B6-BP filter (I'm not sure about the thread, though).
Anyways, I'm not sure why you feel the need to upgrade your oil filter. Unless you replace your oil pump for a higher volume unit, changing your oil filter doesn't really make a difference. I'd say you'd get much better results upgrading to a BETTER filter, like K&N (for superior burst strength, in case you're racing) or Mobil 1 (for better filtering). Other than that, the standard size filter is more than capable of handling the volume the pump delivers.
Diogenes of Sinope.
Diogenes of Sinope.
- umcamara
A larger oil filter allows for a greater capacity of oil, resulting in a relatively cleaner (less concentration of contaminants) oil. Also, a greater surface area of filtering material in the filter should remove more contaminants before becoming blocked.
If you can fit a larger filter, it's usually a good idea.
- Inodoro Pereyra
I guess it's a matter of personal preference. I normally use good quality filters and oil, and change them often.
Diogenes of Sinope.
Diogenes of Sinope.
interesting thread that actually answered my ? about the BP filters. so.. sweet lol.
but yeah I don't see a need either.. I've seen higher flowing oil pumps but.. is there any reason for them?
- Inodoro Pereyra
Sometimes. For example, when you add a turbo/supercharger to an engine, it's good practice to increase the oil flow, to keep everything properly lubricated. Some people prefer to get a bigger oil filter, to cope with the increased oil flow. Personally, I like to use a separate circuit after the pump, with a separate oil filter.Dark_Rider2k3 wrote:interesting thread that actually answered my ? about the BP filters. so.. sweet lol.
Personally, I find using a bigger oil filter when not needed is useless. True, you increase the oil volume a little, but you're using the same amount of oil over a given time period.
Let me explain:
So, let's suppose you change your oil filter for a really big one, and now your engine, instead of holding 3 quarts of oil, holds 4. Given that the engine produces a given amount of contaminants to the oil, now your oil will last 4000 miles, instead of 3000. YiPPPIIIEEE!!! Now your oil is lasting longer!
But if you look at it, you're (obviously) using more oil, so, just like before, you're still burning through an average of 1 quart every 1000 miles. And the trade off is that your car is now about 2 lbs heavier.
Diogenes of Sinope.
Diogenes of Sinope.
- umcamara
More oil also means more heat dissipation, keeping the engine cooler. There's no point in disputing this, if you don't wanna do it, then don't.
I don't remember what the model is, but go to an auto parts store, pick up the m-108 or whatever the model is (mobil 1 or fram or whatever)
there's ONE other size that's the exact same mount and twice the size. I think it might be the m-110 or similar, however, you can just pull the m-108 out of the box, and look at bigger ones, then match the mount.
There's only one which is twice the size.
- Inodoro Pereyra
Whoa, man! You asked for opinions, and I'm giving you mine. If you're not interested, tell me and I won't post here anymore.umcamara wrote: There's no point in disputing this, if you don't wanna do it, then don't.
No need to get your panties in a twist...
Diogenes of Sinope.
Diogenes of Sinope.
- umcamara
I never asked for opinions buddy. If you read my original post you'll see that.
Know your bounds.
Know your bounds.
- beefmobile
dont worry inodoro, he did the same to me
Cars:
2006 Mustang GT-- 12.5 @ 112 mph; NSR Stage II Cams, CMCV Delete Plates, GT500 Throttle Body, U/D pullies, JLT Intake, MAC Headers, O/R X Pipe, Borla Stingers, 4.10 Gears, Hurst Shifter, FRPP Springs, Steeda Strut Tower Brace, Power Steering Delete, Brembo Brakes, Chrome Grille, Cervinis Chin Spoiler, GT500 18" Wheels, Blacked Out Lights, and much much more.
2006 Mercury Mariner V6-DD
2006 Nissan Sentra 1.8 SE-Wife
1993 Mazda MX-3-BEATER!
United States Marine Corps
- Inodoro Pereyra
Well then, enjoy your "mods"...umcamara wrote:I never asked for opinions buddy. If you read my original post you'll see that.
Know your bounds.
One other thing: I'm not your "buddy".
Thanks beefmobile, I'm not worried. I deal with his kind daily at work. People that come to ask a question, and then get upset when the answer is not what they want to hear...beefmobile wrote:dont worry inodoro, he did the same to me
Well, it's his car, not mine.
Diogenes of Sinope.
Diogenes of Sinope.
- Ryan
AFAIK if the base diameter is the same, and the thread looks the same, they will interchange.
I know this because my BP is the same as my B6 is the same as the GF's 1.7 Civic, as my mothers 1.8 Sentra....
Just go to the store and look at ones with the correct base diameter. Worst case scenario, return it.
- umcamara
You two are like little children, and you have no idea what "my kind" is like.
My original question was simply what the larger filter was that would fit, I did not request anybody's comments.
I have provided much for this site over the past few years. What have you provided?
As far as I'm concerned, I'm done with you two.
If you want to take up these issues with me personally, my profile shows my name. Track me down, I'd love it.
- Inodoro Pereyra
Welcome to my "ignore" list prick.
As per your contributions, I think this thread is a clear indication as to their quality. And yes, I do know your kind perfectly, both as what I said previously, and as a know it all internet bully.
And believe me: if I were to track you down, you would NOT love it. You're lucky you're just not worth it.
Diogenes of Sinope.
Diogenes of Sinope.
