how much hp would i net if:
- dash
i put a cold air intake and ram air into my k8?
and before you even start, i know it would be smarter to drop a klze in there.
Who else drives a stock silver 94 GS?
VANCOUVER, BC, CANADA
- dash
Re: how much hp would i net if:
oh, i also know that it would more so make the accelerator more responsive, making me feel faster.
im just interested in the hp i would get.
thank you.
thank you.
You wouldn't net anything, you might free up a couple, and get a cool sound to boot!
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
2? 3? 1?
- fowljesse
In a silver '94 GS, with good compression, you'll get 1¼HP with a good CAI. WIth true ram air like mine, you'll get 2HP.
I've put damn near every bolt on you can onto my K8, and it's still slow as hell. All I care about for now until I get called back to work is that I can beat a b16 and still get good mileage and make my EI stretch hahaha
- muttpower
Depends on the set up you use...meaning if your "cold air intake" is sucking up hot engine bay air, then you wont really gain anything but a nice sound when you blip the throttle. Now If you do a decent custom "true cold air intake", ie. filter located in driver side fender area, etc, than your gains could be anywhere from 2 to 5 hp. The main benifit of the true cold air intake is that when the motor gets to operating temp, the stock filter location sucks up hot air causing a loss in power, where as the cold air intake sucks up cooler outside air. Don't believe the hype about intakes netting 15 horsepower gains. Maybe on a turboed ze with built internals, but not a stock K8.
1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
- dash
on your worklog site there, the intake you've done is "true" cold air, correct?muttpower wrote:Depends on the set up you use...meaning if your "cold air intake" is sucking up hot engine bay air, then you wont really gain anything but a nice sound when you blip the throttle. Now If you do a decent custom "true cold air intake", ie. filter located in driver side fender area, etc, than your gains could be anywhere from 2 to 5 hp. The main benifit of the true cold air intake is that when the motor gets to operating temp, the stock filter location sucks up hot air causing a loss in power, where as the cold air intake sucks up cooler outside air. Don't believe the hype about intakes netting 15 horsepower gains. Maybe on a turboed ze with built internals, but not a stock K8.
did you have to cut a hole, and would i have to fabricate that myself?
- muttpower
Yes, I fabricated my intake myself, and no, I didn't have to cut a hole. There is ample space in the area between the driver side fender and coolant resevoir. It's not too hard to fab up a custom intake. If I'm not mistaken, there's a faq/diy topic on this.
- dash
once again, ive asked a question before searching in any way.muttpower wrote:Yes, I fabricated my intake myself, and no, I didn't have to cut a hole. There is ample space in the area between the driver side fender and coolant resevoir. It's not too hard to fab up a custom intake. If I'm not mistaken, there's a faq/diy topic on this.
what type of metal did you use?
- muttpower
I just bought 3 inch aluminum intercooler piping and a crap load of clamps and silicone couplers. You can normally find piping kits on ebay for cheap. To cut them to size, you can either use a pipe cutter(if you have one) or a cut off tool(much faster).
- dash
i suppose i just buy this stuff at auto parts stores?
or more specific? i would really like to do this.
- muttpower
Like I said, Ebay would be the best bet. But some autoparts/racing supply stores should have it as well. Or you could just go the ghetto way and use pvc piping
- umcamara
Jesse... Just curious to know which color would net the greatest increase in power?fowljesse wrote:In a silver '94 GS, with good compression, you'll get 1¼HP with a good CAI. WIth true ram air like mine, you'll get 2HP.
- fowljesse
The color silver reflects heat, causing the air molecules around the car to be less dense, thereby...
I was kidding.
Here's another one; In Japanese culture, silver is regal, so the workers have a tendency to put more effort into building them...
I'm just making stuff up.
