Shuddering when getting to the limits of traction
Mad Cow
Post by Mad Cow »
If I'm taking a corner really quickly I'll feel the whole car start to shudder right before the tires lose grip and it starts sliding. It also shudders the same way when I shift into 2nd near the redline and get a bit of wheelspin. I figured something is loose or worn out, but what could it be?
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
93vtecklr
Re: Shuddering when getting to the limits of traction
Post by 93vtecklr »
Maybe you don't actually have enough power to break em loose? That's wheelhop, my Datsun is notorious for that with the airride. I wouldn't make a habit of it, or you might be replacing wheel bearings.
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
Mad Cow
Post by Mad Cow »
I've seen videos of wheel hop and it was alot more slowly, this is like a really fast shuddering, around the same frequency as ABS would pump a brake pedal. And I can break my wheels loose in 1st with zero wheel hop.
Ryan
Post by Ryan »
Clutch Chatter?
projectzemx3
Post by projectzemx3 »
whats your tire pressure at?
NEED PARTS INSTALLED? PM ME!
Whisper
Post by Whisper »
Axles binding?
Mad Cow
Post by Mad Cow »
Again it's the same sound when turning as when shifting into second at high rpm. Tire pressure is somewhere around 36-37. And I don't think that the axles are binding because the shuddering goes away completely if the tires break loose and it starts sliding.
Also, this is prbably related but I've noticed that it tends to wander a bit side-to-side at highway speeds.
93vtecklr
Post by 93vtecklr »
Steering issues maybe? Can you feel it in the wheel? And sorry I didn't look at your sig, of course you have enough power.... My bad.
Mad Cow
Post by Mad Cow »
I'm actually not sure if I can feel it in the wheel, the whole car shuddering make me concentrate on that and not notice the steering wheel.
Whisper
Post by Whisper »
Are you dropped at all? Is your suspension at the limit?
Mad Cow
Post by Mad Cow »
I'm not dropped but I have a feeling that I might be on aftermarket springs/struts because the ride is as harsh as my friend's dropped mx3.
Whisper
Post by Whisper »
Well, that's something to check, then.
onlytrueromeo
Post by onlytrueromeo »
Check your bushings, if theyre shot you could have shuddering/harsh ride.
Mad Cow
Post by Mad Cow »
That's what I was thinking too, but where are the important ones located? I just noticed that some of my crossmember bushings are just about gone, would that cause problems?
onlytrueromeo
haha, that would certainly cause problems...all the bushings are important really.
