exhaust set ups
jamesmx3
exhaust set ups
Post by jamesmx3 »
So what exhaust system have you got?
I want to quieten mine, I preferred it when I only had my induction kit on, before i got the system I'm running now which is: Probe header
MaganaFlow HiFlow cat
small silencer
Muffler
I was thinking of replacing the small silencer with a proper box one, at the moment it's a expanded pipe with the wadding stuff in i think:
here's the rest before it was done:
I did think of replacing it all with with standard size pipe but in stainless, but I don't want to spend too much, let me know what you run and how it sounds.
1997 1.6 16v DOHC uk spec gs, 17" wolfrace triad, 2.0l probe s/s header magnaflow high flow cat, powerflow custom catback, CAI, zx2 struts w/ -40mm lesjofors springs
http://www.uk-mx3.com" onclick="window.open(this.href);return false;
jamesmx3
Re: exhaust set ups
Post by jamesmx3 »
everyone running stock pipes then?
Thassodar
Re: exhaust set ups
Post by Thassodar »
I run stock pipes but I know absolutely nothing about exhaust. I have a single pipe muffler and the car runs very quiet compared to when my muffler had two big rust holes in it.
Hey-yo chicken on a raft.
hotsiit
Re: exhaust set ups
Post by hotsiit »
On my stock 1.6l sohc, i ran factory header/exhaust manifold, and then just straight 2inch crush-bent piping (not stainless) to an Apexi Dunk muffler...It was LOUD! A good resonator should help decrease/lower the tone I would think...Or what I did that really made it quieter...add a turbocharger :wink:
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
jamesmx3
Re: exhaust set ups
Post by jamesmx3 »
was thinking of welding this into the system where the expansion bit is after the cat:
http://www.jetex.co.uk/website/images/U336300R.jpg" onclick="window.open(this.href);return false;
might do the trick
Dark_Rider2k3
Re: exhaust set ups
Post by Dark_Rider2k3 »
I know mine with just the muffler tip is annoyingly loud. We should make a thread with the sounds of our exhaust, so everyone can see hear them and make a judgment before they go out and buy one.
jamesmx3
Re: exhaust set ups
Post by jamesmx3 »
good idea!!
