Daninski wrote:Jump TEN and Grd and check the timing. Most Disties are in the middle of the slot just for a starting point. Your RPM should be at 650 with TEN and grd jumped. If it isn't adjust the screw on the top of the TB untill it is. Once you take it out of Diag mode it'll return to around 700rpm.
say what now? lol
