94 4cyl replacing a 93 4cyl
Hey guys,
Just a few questions, I'm buying a motor from someone out here, with a blown head gasket, in the hopes of fixing it and droppig it into my car (110k less, hells yes). I have a 93 sohc right now, and his engine is a 94, which I haven't actually seen yet. What do I need to worry about?
The things I'm thinking about are engine mounts, transmission mounting bolts lining up, sensors, electrical, belts, etc.
Does anyone know if this going to be a difficult swap?
Thanks in advance!
Thanks in advance!
Silver 1994 GS
Black 1993 RS
Black 1993 RS
Re: 94 4cyl replacing a 93 4cyl
93 speedo is cable driven and the 94 are electric. might need the 94 gauge cluster.
NEED PARTS INSTALLED? PM ME!
Is the sensor for the speedo mounted on the transmission? If so, since I'm not replacing the tranny, would I be ok?
Silver 1994 GS
Black 1993 RS
Black 1993 RS
Yes it is and your ok for the speedo sensor then.
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- Ryan
Don't buy it. Buy a BP I made the mistake of replacing the motor with another stock motor. Biggest waste of $500 ever.
- Limegreen mx-3
u can place a b6de in place of a b6me..
u don't have to worry about the mech, speedo cable idk y they brought that up.. nubs
the ? is the wiring part ur current wiring harness and ecu will not run the B6de 1.6 dohc correctly
u'll need to the ecu and wirring harness, maf and other oem BS.
given that u do that there still a chance that it my not even turn on or run right since a u maybe not know what the hell ur doing no offense... and not to many or maybe even a hand full even tried to attempt what u want to do..
if ur insistent in being different go ahead but the cost factor will hurt ur pocket..
so with that said unless u have the time, knowledge, MONEY nothing cheap about a mazda.. as some people might know that..
ur best swap to a dohc is the 1.8 dohc BP and the ecu and wiring harness easy as plug and play.. cost me 700 back in O5.
Now that's an answer I was looking for.
I'll check with the guy to see if he still has the ECU, as well as any sensors, etc. Maybe I can pick up some parts here. The engine has 170k on it, so for $100 imho it's a pretty good deal. The cost of a head gasket & maybe some rings, a water pump, and a wiring harness/ecu might work out to be pretty good. I've done two engine swaps before, both on dumb-estics, it's just different every time, you know what I mean?
Silver 1994 GS
Black 1993 RS
Black 1993 RS
- Limegreen mx-3
replacing the rings is tearing into the motor itself if ur going to that u minus will rebuild the whole bottom end given that ur going to need to take it apart,,
im telling ur go with a BP swap get more power be faster than just doing a dohc 1.6 swap..
the bp is obd 1 compatible with ur sohc than the dohc the dohc mx-3 are i think a hybrid obd1-obd2 mix up if u ask me.. thats y the bp swap isn't plug and play in the 94+ model mx-3
thanks for the comment
The head itself is currently apart from the block, so I don't think it'll be too hard to take off the oil pan and unscrew some pistons, but like I said before, every engine is different, and obviously you know these better than me.
Two last questions then, how easily accessible is the ECU, and would I have to swap out any wiring going into the interior?
If you think it's too much work, I'll look for a BP to rebuild, or a 92-93 sohc.
Thanks for all the info.
Silver 1994 GS
Black 1993 RS
Black 1993 RS
- Limegreen mx-3
easier said than done check this out a lil insight on what u want to do http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=57778" onclick="window.open(this.href);return false;
its not to much work the problem is getting it to run properly and u might get urself into something u wish u didn't get into kicking urself in the butt i should have went BP..
ur the owner u know what u want and ur going to do what u want to do regardless what people tell you.
coming from a from a sohc owner, i sure am glad that i went to the bp swap i have never look back..
yeah the dohc might seem like a steal but when it comes with the extra oem BS that the sohc and bp don't need to run with u'll see what i mean..
the choice is urs ur the boss..
by the way r u auto or standard
It's a standard.
I scrapped the idea, I'll look for another engine to rebuild, thanks for the advice!
Silver 1994 GS
Black 1993 RS
Black 1993 RS
