no tail lights
reys_mx3
no tail lights
Post by reys_mx3 »
i got a 1994 mx3 the tail lights dont work i replace all the bulbs and all fuses are goo but they stiil do not work my dash light dont work also
projectzemx3
Re: no tail lights
Post by projectzemx3 »
brake light switch maybe?
NEED PARTS INSTALLED? PM ME!
tom_finn
Re: no tail lights
Post by tom_finn »
i had the same problem, the dash lights go out when the rear lights go out, to indicate a problem to the driver, one you get the rear lights working the dash lights will work
tom
johnmx3ze
Re: no tail lights
Post by johnmx3ze »
its sounds like a fuse... you should double check or replace the fuses...
colinsmx3
Re: no tail lights
Post by colinsmx3 »
check the tail lamp fuse and hazzard fuse.
Ryan
Re: no tail lights
Post by Ryan »
does it matter if your lights are on or not? do your brake lights work? reverse? hazards?
Absolutely nothing no matter which switches you flick?
Re: no tail lights
you may want to check one of the main fuses under the hood... there is one that controls the taillights, running lights, dash lights... I believe it's a 100amp (or something big)? check it closely as I was baffled since it looked like it was still good.
and like the others have said, check your small fuses...
