Braking = power loss?
I have a 2000 watt volfenhag amp powering 2 10" mtx subs, which really isn't that powerfull. Whenever I start braking, my bass becomes extremely weak. I installed a volt gauge and watched it while braking, but it doesn't drop, stays around 12v. It's only when I'm braking, if I'm sitting idle then the bass is still kicking. If I'm sitting idle with my foot on the brake it's still kicking. Only when im slowing the car down with the brakes is when this happens. Thanks for your help.
14.985@92.54 MPH
Red 93 MX-3 GS, KLZE, 5 speed, Act clutch, short throw shifter, HEI w/blaster 3 coil, PIAA ultra white headights, CAI, Apexi Dunk muffler w/2.5 inch cat back, Avital alarm, dark tint, Sony Xplode 52x4 head unit, Clarion speakers in the front, Pyramid 6x9's in the back, Volfenhag 2000 watt amp, 3x crappy MTX 10 inchers.
Re: Braking = power loss?
It's most likely something to do with the alternator/ idle speed, lower idle lower amount of power the alternator generates. Your battery may be tired if this is the case.
got db's? If your windshield ain't breakin you were taken.........
