help???what about that ebay kit??? klze
hgallegos915
Re: help???what about that ebay kit??? klze
Post by hgallegos915 »
neli_nael wrote:hey hec can this be used to restrict air flow?
http://cgi.ebay.com/ebaymotors/F7-T3-T4 ... 06.c0.m245
For an egay turbo.. you will need THAT and STILL need to kink the line.
They cant handle much pressure. I would run it normal, with that restrictor but as soon as you see the first sign of smoke. Kink it.
you only need around 20 - 30 psi of oil
and we got 60 warm and around 80! cold.
-hec
mx3boyze
Post by mx3boyze »
I see people who run the ebay turbo on KL's without any restictor at all with no problems.
johnmx3ze
Post by johnmx3ze »
i bought one anyways...
mx3boyze
Post by mx3boyze »
johnmx3ze wrote:i bought one anyways...
I guess just see what works for you. But I would NOT reccomend kinking your line btw.
johnmx3ze
Post by johnmx3ze »
ok but how can i know if i have too much oil or not enough going to the turbo???
mx3boyze
Post by mx3boyze »
You can install a oil pressure gauge after an inline restrictor to find out the oil pressure. But is not about the pressure its the flowrate that is to much for the turbo. The restrictor will shoot the oil in at a higher psi but slow down the flow.
hgallegos915
johnmx3ze wrote:ok but how can i know if i have too much oil or not enough going to the turbo???
If it smokes, most likely the culprit.
I wish I didnt have to use one :/
even name brand turbos go on me lol
-hec
johnmx3ze
Post by johnmx3ze »
ok and at what end do i put the restrictor? on the oil sending unit or the turbo inlet?
mx3boyze
Post by mx3boyze »
On the Turbo end.
johnmx3ze
Post by johnmx3ze »
ok thanks
hgallegos915
Its worth looking at probetalk tho..
theres a feeler thread for another msns bulk buy.
:D
-hec
boosted_bullet
Post by boosted_bullet »
correct me if im wrong... but couldnt u run an individual oil pump or something set up to run oil just through the turbo at the flow rate IT needs???? :?: :shrug:
hgallegos915
Yeah you can do that.
-hec
Return to “Forced Induction”
