1.6 sohc info
1.6 sohc info
im trying to find out if a mazda miata 1.6 valve will work on the sohc of the b6e or 1993 mx3 1.6 sohc not not going to swap so please dont tell me to do that
- Ryan
Re: 1.6 sohc info
You want to swap heads, or just valves?
Re: 1.6 sohc info
just valves but im looking to port and polish
Re: 1.6 sohc info
i dont know if they'd fit or not but new ones cant be that much more work/money over used ones and new ones arent that hard to come buy check ebay
Re: 1.6 sohc info
that makes no scene im trying to port and polish... use bigger valves .. where would i get them for a sohc ... not a dohc i dont care nither does my car .. as long as they fit the sameaufgehdraht wrote:i dont know if they'd fit or not but new ones cant be that much more work/money over used ones and new ones arent that hard to come buy check ebay
Re: 1.6 sohc info
sorry bout that i must have read it wrong i don't know if it'd work but get a ruler and take some measurements of what you need and take it down to a speed shop I'm sure they could look em up that way
Re: 1.6 sohc info
ok yea that could work thanks
Re: 1.6 sohc info
has anyone tryed to put a Throttle Body Spacer in if so did it do anything? and if so where did u find it or did u make it?
Re: 1.6 sohc info
The thottle body spacers are useless on our cars.
There is not need for added plenum volume on the 1.6 sohc.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
Re: 1.6 sohc info
ok what about the cam shaft?
and would any parts form a B8 work with a b6 head only>>>
example cam shaft , intake manifold , Exhaust manifold ect.
Re: 1.6 sohc info
the cam probably would free up a few ponies.cricketol2 wrote:ok what about the cam shaft?
nothing from the b8/bp will swap over (except rods and a few select things)
The b8/bp is physically 22 mm longer than the b6 engine , sucks i know.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
Re: 1.6 sohc info
would u have any clue where i could get a cam?
Re: 1.6 sohc info
gude made one for the sohc for awhile.
google would be your friend at this point.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
Re: 1.6 sohc info
i have been looking for 2 years and that was the only place but i would like to know if there was anyone elce that anyone elce know
Re: 1.6 sohc info
contact webcams? see if they can regrind one for you, you probably would have to supply the core.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
