1.6 sohc info
cricketol2
1.6 sohc info
Post by cricketol2 »
im trying to find out if a mazda miata 1.6 valve will work on the sohc of the b6e or 1993 mx3 1.6 sohc not not going to swap so please dont tell me to do that
Ryan
Re: 1.6 sohc info
Post by Ryan »
You want to swap heads, or just valves?
cricketol2
Re: 1.6 sohc info
just valves but im looking to port and polish
aufgehdraht
Re: 1.6 sohc info
Post by aufgehdraht »
i dont know if they'd fit or not but new ones cant be that much more work/money over used ones and new ones arent that hard to come buy check ebay
cricketol2
Re: 1.6 sohc info
aufgehdraht wrote:i dont know if they'd fit or not but new ones cant be that much more work/money over used ones and new ones arent that hard to come buy check ebay
that makes no scene im trying to port and polish... use bigger valves .. where would i get them for a sohc ... not a dohc i dont care nither does my car .. as long as they fit the same
aufgehdraht
Re: 1.6 sohc info
sorry bout that i must have read it wrong i don't know if it'd work but get a ruler and take some measurements of what you need and take it down to a speed shop I'm sure they could look em up that way
cricketol2
Re: 1.6 sohc info
ok yea that could work thanks
cricketol2
Re: 1.6 sohc info
has anyone tryed to put a Throttle Body Spacer in if so did it do anything? and if so where did u find it or did u make it?
nos92mx3
Re: 1.6 sohc info
Post by nos92mx3 »
The thottle body spacers are useless on our cars.
There is not need for added plenum volume on the 1.6 sohc.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
cricketol2
Re: 1.6 sohc info
ok what about the cam shaft?
and would any parts form a B8 work with a b6 head only>>>
example cam shaft , intake manifold , Exhaust manifold ect.
nos92mx3
Re: 1.6 sohc info
Post by nos92mx3 »
cricketol2 wrote:ok what about the cam shaft?
the cam probably would free up a few ponies.
nothing from the b8/bp will swap over (except rods and a few select things)
The b8/bp is physically 22 mm longer than the b6 engine , sucks i know.
93' Rs-t BPT - Sold
cricketol2
Re: 1.6 sohc info
would u have any clue where i could get a cam?
nos92mx3
Re: 1.6 sohc info
Post by nos92mx3 »
gude made one for the sohc for awhile.
google would be your friend at this point.
93' Rs-t BPT - Sold
cricketol2
Re: 1.6 sohc info
i have been looking for 2 years and that was the only place but i would like to know if there was anyone elce that anyone elce know
nos92mx3
Re: 1.6 sohc info
Post by nos92mx3 »
contact webcams? see if they can regrind one for you, you probably would have to supply the core.
93' Rs-t BPT - Sold
